Vbe Multiplier for LM4702 Output Stage
Uhhh ...
To quote Jankinnj from three posts up, "very preliminary" which also means "subject to change". To be very specific, I was asking for examples of what people ended up with and the 'tweaks' they went thru to get there.
I am about to start assembling a project of my based on the LM4702 and was looking to learn from the work already done by others.
Well, I am working on my Beveled THOR's at the moment, so will not play with the LM4702 for a couple weeks.
Reading the review of the new Halcro amp in Stereophile you get an idea why National chose to use the mu-Metal shielding. (and don't get me started on RFI from diode-snubbers, but I think that I am vindicated).
Ah, I see. I don't have all my tweaks done yet, and I don't really know of anybody else who has a FINAL product other than National. They are really happy with the amp in the "new" app note (AN-1490 ), so if you are looking for a final design, I am sure that would work for you.
I am eagerly awaiting a day when I can really get back in my shop and put in some time on this. I hate leaving projects half finished. I will DEFINITELY post when I get a final output stage that I am happy with. Until then, good luck.
David
Carl_Huff said:
Progress report anyone??
Who has built an amp around LM4702 that is willing to share their experience? What output devices did you use?
Toshiba 2SK/2SJ MOSFETs are rally good for this design ;) I think that this is very good configuration when you wont to make simple and good sounding amplifier.
They hint of that in their Application note -- one could make an amplifier of truely stupendous performance with the LM4702 and the '1058/'162 Lateral Mosfet-- now from Renesas, or the competitive product from Exicon. The lateral MOSFETs do not suffer from thermal runaway problems so design is again simplified.
I think that some of the high-end hi-fi equipment magazine reviewers are going to be surprised when they pry open the cases of some kilo-buck amps and find the LM4702 hidden inside. (Perhaps they aren't allowed to do so.)
glennb said:
The Vbe multiplier transistor is not critical. Almost any general purpose NPN small signal transistor can be used! Melbourne, Australia
Glen -- I have used both PNP and NPN -- if you are using lateral MOSFETs the VBE multiplier isn't mounted near the output devices or on the heatsink.
Erno Borbely used a PNP device in his 60 Watt MOSFET amplifier in TAA 2/82.
