Various Tungsram, Toshiba, Philips, RFT, Telefunken tubes
Offer the following tubes, prices are in USD per 1pcs. If quantity is not indicated, that means more than 4pcs available. Matching could be discussed. I would consider swapping for 6BL7 and for EL34.
Twin Triodes
E80CC Tungsram NOS NIB 20USD (mu=27 Ri=7…10k Pa=2+2W)
E80CC Valvo gold pins NOS (1pcs available) 40USD (mu=27 Ri=7…10k Pa=2+2W)
E80CC Philips SQ gold pins NOS (2pcs available) 40USD (mu=27 Ri=7…10k Pa=2+2W)
ECC81 RFT NOS (1pcs available) 10USD (mu=60 Ri=11k Pa=2,5+2,5W)
ECC82/12AU7 Tungsram NOS NIB 15USD (mu=17 Ri=6…8k Pa=2,75+2,75W)
ECC82/12AU7 Telefunken NOS (1pcs available) 30USD (mu=17 Ri=6…8k Pa=2,75+2,75W)
ECC802S Tesla long-plate NOS (4pcs available) 20USD (mu=17 Ri=6…8k Pa=2,75+2,75W)
ECC802S Telefunken long-plate NOS (2pcs available) 250USD (mu=17 Ri=6…8k Pa=2,75+2,75W)
ECC83/12AX7 RFT NOS (2pcs available) 15USD (mu=100 Ri=60…80k Pa=1+1W)
ECC83/12AX7 Tesla NOS (1pcs available) 10USD (mu=100 Ri=60…80k Pa=1+1W)
ECC83/12AX7 Telefunken NOS (1pcs available) 30USD (mu=100 Ri=60…80k Pa=1+1W)
12AX7/ECC83 Toshiba NOS NIB (4pcs available) 30USD (mu=100 Ri=60…80k Pa=1+1W)
E83CC Tesla gold pins NOS NIB (2pcs available) 40USD
ECC84 WF NOS (2pcs available) 20USD (mu=24 Ri=4k Pa=2+2W)
ECC85 Tungsram NOS NIB 10USD (mu=57 Ri=10k Pa=2,2+2,2W)
PCC88 Tungsram NOS NIB (2pcs available) 25USD (mu=33 Ri= Pa=1,8+1,8W)
PCC88 Tungsram NOS (2pcs available) 20USD (mu=33 Ri=2k5 Pa=1,8+1,8W)
E88CC Tesla gold pins NOS (1pcs available) 20USD (mu=33 Ri=2k5 Pa=1,8+1,8W)
E88CC Philips SQ gold pins NOS (4pcs available) 100USD (mu=33 Ri=2k5 Pa=1,8+1,8W)
E88CC Telefunken gold pins NOS (2pcs available) 200USD (mu=33 Ri=2k5 Pa=1,8+1,8W)
6N23P/ECC88 russian NOS 2,5USD (mu=33 Ri=2k5 Pa=1,8+1,8W)
6N23P-EV/E88CC russian NOS 5USD (mu=33 Ri=2k5 Pa=1,8+1,8W)
6N8S/6SN7GT russian MELZ HOLE PLATE NOS (2pcs available) 80USD
6N8S/6SN7GT russian MELZ NOS (4pcs available) 50USD
6N8S/6SN7GT russian FOTON NOS (8pcs available) 10USD
6N8S/6SN7GT russian NOVOSIBIRSK NOS (20pcs available) 2,5USD
Pentodes
S2001 Matsushita NOS NIB (5pcs available) 25USD (Pa=20W) (rare for old radios)
PL36 Tungsram NOS (2pcs available) 10USD (Ri=5k Pa=10W)
E80L Philips SQ gold pins NOS (3pcs available) 15USD (Pa=8W)
E81L Tungsram NOS NIB 15USD (Ri=200…300k Pa=4,5W)
PL83 Tungsram NOS NIB 20USD (Ri=100k Pa=9W)
6AQ5 Toshiba NOS NIB (2pcs available) 15USD (12W)
EL803S Telefunken black plate NOS NIB (2pcs available) 40USD (Ri=60k 7,2W)
EL95 Yugoslavia NOS 10USD (Ri=80k Pa=6W)
EL95 Siemens NOS (1pcs available) 10USD (Ri=80k Pa=6W)
EF80 Tungsram NOS NIB (1pcs available) 10USD (Ri=500k Pa=2,5W)
EF86 Tungsram NOS 10USD
EF86 RFT NOS 20USD
EF860 RFT NOS (1pcs available) 10USD (Ri=550k Pa=2,1W)
6Z32P russian NOS 5USD
Heptodes
E81H Tungsram NOS NIB 10USD
Triode-Pentode
ECL82 Tungsram NOS NIB 10USD (Pa=1W; 5W)
6BM8/ECL82 Toshiba NOS NIB 20USD
PCL85 Tungsram NOS NIB (2pcs available) 10USD (Pa=1W; 7W)
Triode-Heptode
ECH81 Tesla NOS (1pcs available) 10USD
E80CC valvos Swapping for 6BL7?
Best Regards
Yes, I would swap one by one, if you agree to test-measure the 6BL7.
I need to know tubes manufactuter, and plate currents of each triode (half) of 6BL7 at -8V fixed grid bias and 200V plate voltage. From my side, I agree to measure the E80CC at bias and voltage indicated by you.
If 6BL7 measurements acceptable, I will ask fotos of them.
Some more items have been added
For three stage schematics, the ECC802S tube is perfect at input, it has low Miller, low output impedance, wide bandwidth.
Also offer discount, valid until 1st of April 2017, minus 30USD, if amount is higher than 130USD.
Additional item is offered, 6P14P-EV, Saratov, NOS, 12pcs, all the same date 1973 year VI month. Price 15usd/pcs.
The -EV extension in the type name means enhanced quality, stability and durability, gold plated grid, nickel plated pins.
Western substitutes for 6P14P-EV - EL84M and 6BQ5.
Offer Tesla E83CC Gold Pins, 4 pcs, new, same date, tested.
25usd/pcs, shipment is 10usd worldwide with tracking.
Simplified measurements are done with self bias 261R (0,5% accuracy)resistors at 270V plate voltage. As per datasheet, 0,98V voltage drop is expected on 261R resistors at this voltage.
The readings obtained are
1) 0,99V и 0,97V
2) 1,07V и 1,01V
3) 1,01V и 0,97V
4) 1,00V и 0,93V
I HAVE interest in the tete 802's
The pair if Tele ECC802S is available, enclose actual pictures.
Some time ago I rough tested them, with 787R precision resistors in cathodes of both halves.
At plate voltage 150V, readings of voltages at cathode resistors are
tube 1 _ 4,89V 4,63V
tube 2 _ 4,58V 4,52V
At plate voltage 250V, readings of voltages at cathode resistors are
tube 1 _ 8,69V 8,24V
tube 2 _ 8,15V 8,06V
