Variable PS question
I breadboarded the attached variable ps from redcircuits, Variable DC Power Supply - RED - Page36. I didn't have Q1 BC182 or Q3 BC212 so I substituted 2N5401 / 5551. The transformer is a 17-0-17, 4.7A toroid. Everything else was the same as the schematic. I'm not sure if I'm testing it properly. I hooked it up to a 100 watt light bulb and put my voltmeter across the output and another DMM set to mA in series with the light bulb. I have a reading of 20 vdc and ~ 330 mA with both pots turned fully cw. Is a light bulb a suitable load? Is it common practice to short the output to measure current or is that a bad idea. Thanks for any comments or suggestions.
A 100 watt AC incandescent bulb is not a suitable load.
Shorting the output isn't really a good idea either, unless specifically testing that function of the power supply circuit.
24V @ 2A is 12 ohms and 48 watts. Do you have power resistors to make that value?
Realistically, you probably can't get a full 24V out with your transformer.
The 0.7V low end spec is suspect also.
If you have any 12VDC halogen bulbs handy those would make good test loads.
