I found the following ( +ve) voltage limits for the heater to cathode voltage for the 6922 tube.
1. Telefunken 150 V
2. Raytheon 70 V
3. RCA 120 V
4. ( E88CC ) 50 V
Do they really vary so much between different makes?
Does anyone know the published limits for the Sovtek 6922 and Electro-Harmonix 6922 ?
Thanks.
1. Telefunken 150 V
2. Raytheon 70 V
3. RCA 120 V
4. ( E88CC ) 50 V
Thanks.
ashok said:Do they really vary so much between different makes
Probably not, but the testing method and limits applied probably do.
Re: Re: Variable 6922 heater to cathode voltage limit...?
Indeed.
And moreover, isolation between heater and cathode gets worse over time. Certain datasheets (*) even define one of the "end of life" conditions for that tube via h-k leakage current at stated positive and negative h-k voltages.
So, h-k ratings given by manufaturers really depend on a lot of additional conditions - what they think is acceptable under the circumstances they considered.
Maybe the sometimes very lowish h-k ratings especially found for ECC88 and the like are not oriented so much at actual h-k isolation capabilities, but much more by noise issues and demands - considering the original/native and intentional usage ECC88 was designed for.
Regards,
Tom
(*) F.e, see Philips E188CC datasheet.
EC8010 said:Probably not, but the testing method and limits applied probably do.
Indeed.
Regards,
Tom
