I have an option to buy these speakers (set of 2), but want to know:
1) What is a realistic 2nd hand price for them, taking into account that they are about 7 years old and the 1 got a dent in the dustcover.
2) How can I remove the dent?
I am listening to them now on my modified Mullard 5-20's and they sound really AWESOME. I cannot hear that the dent cause any interferance of any kind.
Thanx for any suggestions.
SPECS:
KLIPSCH KG 4.5
FREQUENCY RESPONSE:
36Hz-20kHz±3dB
SENSITIVITY:
95dB @ 1watt/1meter
POWER HANDLING:
100 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Bass reflex via front-mounted port
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) polymer dome
compression driver tweeter with a 90°x60°
Tractrix® Horn and one 10" (25.4cm) ICG cone woofer
TWEETER:K-85-K 1" (2.54cm) Polymer dome compression driver
HIGH FREQUENCY HORN:90°x60° Tractrix® Horn
HF CROSSOVER:
1600Hz
WOOFER:
K-1005-K 10" (25.4cm) Injected Carbon Graphite cone
DIMENSIONS:
37.5" (95.3cm) x 12.25" (31.1cm) x 12.75" (32.4cm)
WEIGHT:
54 lbs. (24.5kg)
ENCLOSURE MATERIAL:
Medium density fiberboard construction (MDF)
YEAR BUILT:1996
And a pic of them and the ugly dent.
SPECS:
KLIPSCH KG 4.5
FREQUENCY RESPONSE:
36Hz-20kHz±3dB
SENSITIVITY:
95dB @ 1watt/1meter
POWER HANDLING:
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
DRIVE COMPONENTS:
HF CROSSOVER:
1600Hz
WOOFER:
DIMENSIONS:
WEIGHT:
54 lbs. (24.5kg)
ENCLOSURE MATERIAL:
YEAR BUILT:1996
- Value - Klipsch KG 4.5
