Vacuum tube amp design
Hi there.
Im in the process of building a stereo vacuum tube amp,with a ecc88as preamp ,ec80 and a pl36( single ended output),I have already made a design shown in the pic below.Would the diagram shown below be ok ?
Administrator
Joined 2004
Dug, looking at the schematic it appears that the ECC88 has 150 ohm cathode resistors on both sections.
There does seem to be a lot of gain here, probably 26 - 28dB in the SRPP alone.
I believe you want a resistor in the screen supply of the EF80, probably in the vicinity of 4X the plate load resistor. The 68K resistor on the grid of the EC80 will contribute significant noise, I'd reduce this to 10K or less if there are no stability issues with this pentode. What is the load? (Don't recognize your symbol)
I assume the ECC88 cannot swing sufficient voltage to comfortably drive the PL36, it's not a familiar type and I have not checked. I would add the missing grid resistor and probably a grid stopper (1K or so) right at the socket to reduce the likelihood of oscillations.
45
Account Closed
Joined 2008
The EL/PL36 is a nice device when triode strapped. It is rather linear and has low plate resistance (around 650R) but good gain because of the healthy gm. At 200-220V/60-70mA and 2.5-3K primary load you only need about 30V peak to get about 2.5-3W at 5% THD.
In PP Class AB1 triode strapped things become very interesting...
The EF80 has quite a high gm, and therefore only a limited grid swing between cutoff and grid current. You have put quite a lot of gain in front of it. I am puzzled what your source is, that needs so much gain.
The resistor (1k/1M?) from the first triode anode to ground should be omitted. If 1M it does almost nothing. If 1k it shorts the anode.
My guess is that the PL36 output needs a rather smaller value for grid leak than 1M. Check the data sheet.
As to 'OK for a stereo tube amp' my answer would be no, but those who like SET sound would differ.
Okay so I found a simpler schematics that uses a PL36,but my problem is that for a stereo i need two ECC82,but I have only one.Then I checked the datasheet and it was very similar to the PCC88,has the same pinout and looks very similar ...
Can I use the PCC88 in the place of the ECC82 in this schematics,or do I need to change anything :scratch1:
45
Account Closed
Joined 2008
But it would work OK ? which resistors must I change,and how much power could this amp produce ?
Would the PCC88 and PL36 work ok for a stereo amp ?
The PCC88 is basically identical to the ECC88 except the filament runs at 7.6V/300mA instead of 6.3/365mA.
As you need about 260V supply for the PL36 (5-10V drop across the primary of the transformer, 220V plate voltage and 30V bias) you have enough supply to run the PCC88 properly. From the 260V supply make 1-2 RC filters in order to get about 220V. The PCC88 will have 22K anode resistor and 600R cathode resistor. This way it will run at about 110V/5mA with -3V bias. The gain will be nominally 26.5 which means that you will get full power with about 0.8V rms input.
So you only need one PCC88 for both channels. It is not very sensitive for my taste but should be enough if you use a CD player or computer.
