I have Visual Analyzer 2011 – a freeware PC based oscilloscope program. The program has essentially no documentation; it assumes you’ve used an oscilloscope before.
I’d like to do the traditional measurements for an amp and preamp (freq response, distortion, etc). Can someone point me in the right direction for a “how to” to newbies on doing these measurements?
Build pete millet's Soundcard Interface
so you won't fry your soundcard.See if he has some boards left to order.
See old posts of visual analyser there are some links to english documentation.
The 'scope software by itself cannot do distortion analysis except to display gross aberrations of waveforms -- assuming you know what the waveform is supposed to look like. The 'scope draws a graph of amplitude (usually voltage) on the Y-axis (vertical) versus time on the X-axis (horizontal) -- a fine analytical tool for many things that I think is absolutely indispensable. So once you establish a reference level and frequency, then you can see level differences at different signal frequencies, which is what frequency response testing is. Fine differences are hard to see, but 1dB of level change is about a 10% change in level, so you can do fairly accurate measurements with the 'scope, especially if you are careful to always check the output signal level of the DUT (device under test) against the actual input signal level driving it.
But the ARTA suite of software (free download) can be used almost without limits in demo mode and uses its signal source through the PC's sound output to do frequency response testing, showing a typical graph plot of level vs. frequency, and can do distortion analysis with its built-in signal source and spectrum analyzer. I think this will be of more use to you than the basic oscilloscope program, although that is a useful tool.
I would suggest that you Google "testing audio amplifiers" and "using electronic test equipment", "using oscilloscopes" etc, then follow links -- it's all out there, but sometimes finding it is hard, especially at the entry level. Initially, of course, the hard part is learning the lingo.
I see that ARTA can be used to test speakers. I cannot tell if ARTA can be used to test amps for THD, etc. I built the test box indicated on the ARTA website, but I have not had the chance to try it yet.
@NYCOne -- Yes, ARTA can give spectra of amplifier distortion products and calculate both THD and THD+Noise. Be aware that the residual distortion is limited by the THD of the sound-card/input device you use with it, and that the measurement bandwidth is limited by the sampling frequency Nyquist limit of somewhat less than 1/2 the sampling freq., which means that seeing harmonic up to the fifth will limit the input frequency to about 1/12th the sampling rate of the analog-to-digital converter system.
For the 16-bit, 48kHz converters in many PCs, the limits will be around .005% and an upper frequency limit of about 4kHz for realistic measurements. My PC's 24-bit, 96kHz internal Intel HD Audio system will do around 0.002% with frequencies up to about 8kHz. My EMU 0204 24-bit, 192kHz USB ADC will do around 0.001% and an upper frequency of about 16kHz.
By using a Twin-T active filter to notch out the fundamental by 60dB, and then driving the EMU, I can get THD readings below 0.0005% (5 parts-per-million), which is pretty good. Individual harmonic products can be seen to well below -130dBu.
See my web-page on the active Twin-T at Active Twin-T filter.
- Design & Build
- Software Tools
- Using PC Oscilloscope freeware as a distortion analyzer
