Has anyone ever used Digital isolators in SMPS design? The big advantage I see is the much higher switching speed, but I am curious if any has run into issues using them.
http://www.analog.com/en/interface/digital-isolators/products/index.html
I've used them for digital bus/control signal isoation in a strain gage amp, seem OK so far but I've not started testing EMI performance
read the app notes carefully, these do use magnetic coupling so it's possible putting them in a really bad spot could be problematic in a SMPS - know where your sw currents flow, and how far your magnetic component leakage fields reach
Hi
I have used them to pass the PWM signal (PWM controller placed on secondary side) over the isolation barrier to driver circuit.
What I noticed is that at start-up when input side has an undefined supply voltage level (around 2 - 2.5V), the output generates some narrow pulses.
Those pulses can trigger your logics if, for example, such a digital isolator is used on a fault line.
It was the case of ADUM1100 but the manufacturer knows that behavior and I think they solved the problem by now (it happens about 2 years ago).
