Hi.
This has been debated a lot and i have searched old threads but did not find an answer. So here goes:
I have an opportunity to buy one or more old scopes' from the list below:
Tektronix:
465
475A
485
2225 (550Mhz)
2230 (digital)
2235 (100Mhz)
7632 (Storage)
Philips
PM3218
PM3267
All of them should be in working order and have been calibrated on a regular basis.
And now the impossible question: What to buy?
I'd like to measure audio AND digital signals (<1Mhz).
I'm working with PIC's, audio (low-level, class AB, D) and whatever comes my way.
I know that one scope might not be enough, but I could buy more than one.
Please comment.
Regards TroelsM
Tektronix:
465
475A
485
2225 (550Mhz)
2230 (digital)
2235 (100Mhz)
7632 (Storage)
Philips
PM3218
PM3267
Please comment.
Regards TroelsM
One thing you forgot to mention is the prices...
Depending on what they are can better decide
which is a good buy.
The 250Mhz Tek 475A is a great scope and a work
horse. Prices should be around $200.00 working.
Also the 2235 is a good scope around the same price.
The 465 is to old. If it was a 465B it would be OK..
Steve @ Apex Jr.
Steve @ Apex Jr.
Hi!
Thanks for the fast reply.
The scopes are on auction but the prices should not rise to high as it's an "closed" auction with people from my firm.
I know that the 465 is getting´ old by now, but if the price is right and its in perfect condition?
Keep the advise coming´
Regards TroelsM
Regards TroelsM
The 465 is the 1st of it's type there have been 3 revisions
with the 465B with both the DM 41 and DM44 options.
YES, your right if it's cheap and working it's a good scope.
The 485 scope is 350Mhz and has a very small screen
like the 453 scope and I would prefer the others.
Steve@ Apex Jr.
Steve@ Apex Jr.
I would get the 7623. (Check your model number. Tek didn't make a 7632 http://www.tek.com/Measurement/cgi-...pport/faq/history.html&FrameSet=oscilloscopes ) The plugins are cheap on eBay and you can do almost anything with it. Make sure its healthy, storage CRT's are delicate.
-Demian
-Demian
I personally have a 475A, and I love it. Unfortunately, I don't have a lot of experience with the others you listed, but if this one is under $250 I wouldn't hesitate to pick it up if it is indeed in good condition. Be sure to check the focus and brightness of the CRT!!
David
Oh, and I have never heard of anyone I know using a Philips scope, so that should tell you something. Tektronix and HP are the only two brands of scopes you should consider IMHO. Sort of like Flukes and DMM's.
David
Hi TroelsM,
I have a Philips PM3070. Many problems, I do not recommend them at all. The faults seem to be heat related. The later "combiscope" was offered, but I rejected them based on how much hotter certain parts got.
I'd be looking at the Tek scopes. The 2235 (I'm trying to fix mine) is a good scope.
-Chris (for what it's worth)
No, we don't like Philips 'scopes over here either (poor triggering). I used to have a Tek485 until its EHT supply expired. Where did Tek hide it? Deep inside so that there wasn't a hope of probing it to determine the fault. After a few attempts at fixing it I gave up. Shame, I liked it, even though the screen was quite small. And I preferred it to the 465B. I'd avoid any early digital storage 'scopes. They have a low sample rate, short memory and are a nightmare to drive.
Hi EC8010,
Sadly, it was still the right choice at the time.
-Chris
Can't argue with you on that at all. I went with an analog (Philips) instead of the much better quality HP digital at the time. Resolution.I'd avoid any early digital storage 'scopes. They have a low sample rate, short memory and are a nightmare to drive.
-Chris
EC8010 said:I used to have a Tek485 until its EHT supply expired. Where did Tek hide it? Deep inside so that there wasn't a hope of probing it to determine the fault. After a few attempts at fixing it I gave up. Shame, I liked it, even though the screen was quite small. And I preferred it to the 465B.
I have received much help for Tek scopes on the Yahoo TekScopes group http://groups.yahoo.com/group/TekScopes/ . If you still have the 485 you might be able to get a working HV module from someone in the group. They also can help with suggestions on scopes and sources for info.
-Demian
EC8010 said:No, we don't like Philips 'scopes over here either (poor triggering).
Hewlett Packard worked overtime for about a decade and half to figure that problem out...
1audio said:I have received much help for Tek scopes on the Yahoo TekScopes group http://groups.yahoo.com/group/TekScopes/ .
Thanks for the pointer. Unfortunately, the 485 fell foul of the two-year-rule and went for landfill.
jackinnj: Interesting you should mention HP; when I evaluated an HP54600B its triggering was fine.
Ditto. The triggering was fine. It would even display an eye pattern! It just didn't have the fine detail required. Otherwise it was a fine 'scope.jackinnj: Interesting you should mention HP; when I evaluated an HP54600B its triggering was fine.
-Chris
You call that small!?!?!?!?john curl said:If you want the best, yet small scope, get the 485. It is a great scope.
I would love one of the new TDS2000's but until my 485 dies, there is no way.
- Design & Build
- Equipment & Tools
- Used scopes...
