I have a USBStreamer from the new batch Oct-2014 (with a new eeprom) and have issues to get 192Khz SPDIF sync working. Using my own opto cable it works until 176.4 kHz and with the given opto cable (ends looks like a shower head with plenty of stray lights at the ends) and 96kHz will even not sync.
Does some else have same issue and got a better ToshLink receiver as mentioned JensH http://www.diyaudio.com/forums/minidsp/214068-usbstreamer-multichannel-usb-audio-interface-4.html#post3504588 #31
Any reply on this regard is welcome... even from miniDSP...
Hp
Hp
Are you testing this with a loopback connection, or some other scheme?
I did the test in a loopback connection and also feeding the USBStreamer input from a RME HDSP card, where the loopback on the RME works perfect at 192kHz.
How your USBStreamer works?
Hp
Mine seems to work okay with a 192khz loopback. However, it's pretty finicky because if I manipulate the connectors a little bit it loses connection.
Do you use the given with the USBStreamer? If it's the case how the optical ends look like?
The best endings have a very clear cut. You may do the same do scrape with a sharp scalpel. If you connect one to and optical output and have the second opened, you should see a very clear light (not like from a shower brush ).
Some do a tweak using a liquid for better optical flow
Hp
I have one of the little tape dispensers used for minor prepping of fiber cable ends.
The cables shipped with the USBstreamer don't look too bad. I have a couple of other cheap cables but they don't work any better (or worse.)
Why don't you swap out the transmitter/receiver blocks as Jen has done?
His streamer interface seems like an excellent addition too.
I don't use mine that much and I only have 96khz (maximum) content, so this project will go near the bottom of my to-do list.
Dave.
Dave.
The replacement parts has been provided by miniDSP... and I am still waiting to get any feedback from the support...
While it culprit could also be the receiver PLL circuit ...
Hp
