I know this has been asked a few hundred times, but hey... I really want to build a tall narrow chassis for my f5, I know upright is less efficient and therefor more expensive but I cant help myself.
Nelson says:
At 1.3 amps per channel, you will see idle heat dissipation of 62 watts. To keep the temperature rise of the heat sink to 20 deg C. above the ambient temperature, you will want a heat sink rated at about .6 deg C./watt for each transistor. An example of this would be a chunk of finned aluminum, with a series of 2” fins attached to an 8” by 6” base. You will need two per channel.
So for 1 channel I would need a 2"D x 6"W x 16"H with at least a 1/4" plate
as a minimum size.
Does anybody know of a supplier of this type of design/dimensions or an alternative that I might build myself??
Can I stack smaller sinks and link them somehow?
I am open to any suggestions no matter how weird.
Cheers all
Dean
Nelson says:
as a minimum size.
Cheers all
Dean
Is it possible to use something like this
Conrad Heatsinks - Products
Perhaps the MF35-100?
Standing upright, with the fins running horizontally? Surely this is a bad idea
Check out this thread...
http://www.diyaudio.com/forums/pass-labs/173528-fs-f5-heatsinks.html
Steve @ Apex Jr.
Steve @ Apex Jr.
Just found this at the ESP site, basically says horizontal fins is a crap idea.... Back to the drawing board.
ESP - Heatsink design and transistor mounting
Nelson says:.........An example of this would be a chunk of finned aluminum, with a series of 2” fins attached to an 8” by 6” base.
No!So for 1 channel I would need a 2"D x 6"W x 16"H with at least a 1/4" plate
as a minimum size.
The dissipation capability of a heatsink is roughly proportional to the sqrt(height).
It is also roughly proportional to the width.
If you start with a 8"w by 6"high with the 20off 2" fins vertical, then double the heat dissipation capability comes form 16"w by 6"h with 40off 2" fins, or 8"w by 24"h with 20off 2" fins.
But, there is another factor to consider.
This assumes that the whole backplate is isothermal (all at the same temperature).
If the back plate is relatively thin compared to it's area then parts of the backplate will be much cooler than the contact spots at the heating devices.
8" by 6" with two devices near the middle has a maximum radius from device to farthest corner ~3.5" This will require a back plate ~3.5/10 = 0.35"
If you increase the backplate to 16"w then the thickness will need to be ~7.5/10 = 0.75"
Similarly for the 24"h sink, recommended thickness ~1"
Your 1/4" backplate will run very hot where the devices are mounted and run much cooler at the extremities.
heatsink manufacturers' datasheets and application notes.Just courious, why is it sqrt (h) but direct proportional to the width ? Where does this calculation come from ?
HeatsinkUSA
He has a variety of widths which he will cut to your length.
Bear in mind AndrewT's good advice before you go down this road.
A pair of 10.08" by 10" back to back with the devices clamped between will be capable of dissipating enormous power. These have 3/8 backplate and 2.5" fins
This could be for a paralleled F5 or a balanced F5, since both versions have 4devices (or even a Stereo F5). Place an N & P in contact with one sink and turn over another N & P to contact the other sink. Bolt the sinks together and mount them on a pole (pole dancing?) above the PSU and voltage stage.
Nice one guys and point taken Andrew, I did ask for input on the subject and appreciate the maths. I need to look at all my options again with this info in mind.
The idea is for a taller final product, think 3-1 ratio, but considering Andrew's advice it makes sense why nobody builds amps like this.
Looking through the heatsink USA catalog now.
http://www.frigprim.com/online/natconv_heatsink.html
Did anybody have a go of this Java app, Andrew or other, does it seem like a realistic/easy way to spec a heat sink when building?
Cheers
Dean
Cheers
Dean
From looking at various datasheets (Fischer) I would say that´s a very rough estimate at best.
Brilliant software.Natural convection heat sink
I have recommended it to builders a few times after I found a reference here on the Forum.
This Forum is a goldmine of information.
- Design & Build
- Parts
- Upright Heat sinks for f5
