There's my universal smps from parts from pc power supply.If it don't start to oscillate,reverse feedback windings (15k resistor).I'll test it on some amps,and it works great.PCB is without rectifier,I'll finish it later.
its real can produce 1kw?Full bridge,1kW:
what driver you are suggest?
sorry my english.
Full bridge,1kW
Acca, is this your project or someone else's example did you?
Cheers
Full bridge,1kW:
Cheers
with no feedback... whether the drop voltage will not happen?Full bridge,1kW:
or...how your suggestion
regards.
Drop will happen but if you make a good transformer... drop was smaller than 50hz transformer on heavy load.with no feedback... whether the drop voltage will not happen?
regards.
- Power Supplies
- Uni SMPS
