Ultrasimple MM/MC RIAA Preamp mkIII
A friend of mine (Ludo) tweaked the circuit by Mads K.
I a having trouble getting it to work so I thought I post it here for some discussion.
Conrad Hoffman said:
You're at the mercy of whatever current flows with the gates grounded (Idss?, I forget), and this can vary. You might have to adjust the upper three resistors to get the voltage drop you want. Other than that, it looks like it should work fine. I assume the gain is rather low and another gain stage has to follow this.
I guess so...
Conrad - this design stems from here: http://www.diyaudio.com/forums/showthread.php?s=&postid=1550522
and the unit, as designed by Mads K works just fine as it stands with my Kiseiki Purpleheart Sapphire low output MC cartridge...!
D
