Jan-Peter said:Steff,
Because of the internal boost trap circuit to drive the positive fet you have an output voltage of 12VDC when the amp is OFF and without a load. You can remove this high impedance DC voltage when you connect a 47k resistor from the output to -V.
Or the best way would be to use a 12V zener and 33k from the output to -V. The kathode of the zener should go to the output of the amp, anode to the resistors and other side of the resistor to -V.
Regards,
Jan-Peter
Thanks JP for the answer.
But where come from the -20.6V with no charge and MUTE ON?
And why 180mV with 100 Ohms charge?
I can see the 12V when MUTE is OFF with no charge.
Jan-Peter said:??? I don't know....
Does the amps works ok?
Perhaps you can post the full schematic of your setup?
JP
Not done yet but the test circuit is really simple.
PSU (MBR10100 + BHC ALS10S = 42V) -> module (mute directly soldered on GND)
Input shorted. Output tested with charge and without charge. For the test, the GND is not connected to the box. I test the speaker output directly. The DC protection circuit have been completely removed.
The module have been tweaked as this : new op-amp OPA2134 and coupling caps replaced with 47UF BG NX HiQ (no 22UF in stock sorry).
The module works well connected to a 4 Ohms speaker.
What's the dark side of the zener+resitor tweak?
Bgt said:Steff, how about the heat build up with closed lid and working for some hours?
I tested only 5 hours box closed. More hot than I was thinking. The plate has to have holes above modules for vent but no more. The temp stay cool.
Untill you measure the various parts.The temp stay cool
Hi all,
I am considering a pair of UcD180 modules to play with... but before I know what I'm dealing with, I would prefer to use some 24V transformers I have at hand (to keep costs down).
Is this possible, or will I get into trouble?
(I saw the data sheet for the UcD400, hich would indicate problems with my supply voltage being too low.)
Jennice
Jennice
On Hypex's website under technical documents UCD180 user's manual, it recommends a minimum of +/- 30V for "optimum sonic performance".Jennice said:As low as +/-20 V DC? where do you read that (any link?)
Do you know about the low limit for the UcD400, also?
Jennice
http://www.hypex.nl/docs/UcD180_manual.pdf
For the UCD400 it says +/- 45V.
http://www.hypex.nl/docs/UcD400_manual.pdf
stef1777 said:I've found this page surfing.
http://www.ciaudio.com/D100.html
The specs are close to the UcD180 module!!! May be inside?
You're right. There's a review of it with full measurements in the August edition of Stereophile.
Yup,
and the D200 is Ucd400 it seems!
Check out the prices!
Check the reviews on audiogon: Audiogon
I'm going to scare my local high-end store when my dual UcD400 gets finished
Bruno and/or Jan-Peter, are you allowed to tell me how "custom" the modules inside the channel island audio's are?
I've looked at Hypex' web page, and it seems two versions are available. The only difference seems to be a (costly !) buffer change.
What versions are you guys (fellow DIY'ers) using?
Bruno: The signal connector looks a lot like the power connector for a 3.5" floppy. Is it the same?
Jennice
Jennice
- Class D
- UCD180 questions
