Tubes at low +B...
Why not convert?
You may remember the old vibrator power supplies, used in old car radios. These were used specifically for B+. The more modern equivalent is to use a 555 timer to drive a MOSFET. I don't understand your desire to run a [non 12V] tube at this low voltages. :confused: DC-DC conversion allows you to have the optimum B+ for whatever design you choose...Of course if your wish is to see if it can be done, you sound like you are already well on your way!
Good Luck!!
Alastair E said:
I was experimenting at 12V as I didnt want inverters etc or voltage-doublers as its to be used in the car., direct off the usual 12-14V supply
I quite like the challenge of restricting myself below 15V just to see what can be done with the common audio valve types like above, rather than the special Car-Radio tubes made specially for 12V.....(I havent actually got any of those 'specials' 12V valves at the moment either!)
:bawling:
Yeah, I guess he likes the challenge.
I have built his posted schematic and it works with a 6SN7.
6SL7 is not so good though. The 6SL7 seems to struggle a little on 24V.
I have to say that this low B+ concept has opened my eyes to the possibility of diy tube circuits.
Just wish I'd known more before spending £80 on a 'Tubalizer'. :bawling:
Martin.
Alastair E said:
shameless bump...Sorry!:smash:
Are you bumping about the battery life? The typical 9v is made up of six AAAA 1.5v cells, which have a 625mAh lifespan for alkaline... twice that for lithium. NiMH rechargables are actually 1.2v cells, so you get 7.3-8.4v at 250mAh. if you are going rechargable, you may want to consider a Li-ion flat pack like in a cell phone or MP3 player. They are 3.6v cells, so you can get them in 10.8-11.1v for around $20. A lot of them will shut off below a certain voltage though.
AA batteries are probably a better choice if you have the room... or even AAA. AA Alkalines are 2800mAh, and AAA are 1,200mAh, which is 2-4 times better than a 9v.
