Tubes as preamp..
Re: Vibration....
rt7085 said:
I would not recommend using tubes in a car as vibration is a tubes greatest enemy. This will break. Also, if you want to use them, you may need a step-up supply as they run on voltages much higher than the battery supply in a car environment.
I had a tube system in my car for over 6 years (4 12AX7s and 4 5881GC's) with absolutely no problems. Tubes have been used in rugged applications for quite a long time with a good track record. Soon enough I shall be putting another tube system in my car.
Hi, Ryssen,
You can try this, ECC88 (or 6DJ8), supply voltage is only +/-24V (You'll need to build an SMPS, though, but not a lethal voltage one :D)
