Hi everyone,
I'm about to buy the Tubelab SSE PCB and its parts on mouser.com and ebay. Since i am not an expert can you please help me by checking if the links are showing the correct parts?
Thanks a lot
0.22uF 600V - 4x Vintage Mixed Dielectric Dubilier Capacitors 0.22uF 600v Old Radio TV Etc | eBay
0.47uF 100V - ECA2AMR47 - PANASONIC - CAP, ALU ELEC, 470NF, 100V, RAD | Farnell UK
100ohm 1/4W - Pack of 100 1/4W carbon film resistors pick value from 100 to 10k Ohms FREEPOST | eBay
100ohm 2W - 2w Watt 100 Ohm 100 R Metal Film Resistor (20 Pcs) MPH | eBay
10k 1W - 5x 10000/10K/10K0 ohm 1W /1 Watt Metal Film Resistor | eBay
10k 3W - 3w Watt 10 K Ohm Metal Film Resistor (10 Pcs) | eBay
120uF 500V - Nichicon Aluminum Electrolytic Capacitors - Snap In | Mouser
1500uF 50V - PANASONIC - EEUFC1H152L - CAPACITOR, RADIAL, 50V, 1500UF Price For: 5 | eBay
1500uF 6.3V - 6.3YXG1500MEFC10X20 - RUBYCON - CAP, ALU ELEC, 1500UF, 6.3V, RAD | Farnell UK
150k 2W - 5x 150K/150K0 ohm 2W /2 Watt Metal Film Resistor | eBay
150k 3W - 3w Watt 150 K Ohm Metal Film Resistor (10 Pcs) | eBay
150ohm 5W - 5W 150 Ohm Wire Wound Ceramic Cement Resistor x10 Pcs | eBay
1k 1/4W - 100pcs 1K 1000ohm 1/4W 1% accuracy Metal Film Resistors | eBay
2-pin terminal strip - New 2-pin/3-Pin 5mm Pitch Plug-in PCB Panel Screw Terminal Block Connector Mount | eBay
220k 1/4W - x100 pcs 220k 0.25W (1/4 watt) 5% Carbon film resistors 1st class post uk | eBay
220ohm 1/4W - 100 PCS. 220 Ohm 1/4W 5% Carbon Resistor Bargain pack | eBay
3-pin terminal strip - 100 PCS. 220 Ohm 1/4W 5% Carbon Resistor Bargain pack | eBay
330ohm 1/4W - 200pcs Resistors 330K Ohm 1/4W 1% Metal Film Resistors | eBay
47uF 500V - CAPACITOR ELECTROLYTIC RADIAL 22uF 33uF 47uF 500V 20% 85°C SAMWHA SD2H 7.5mmP | eBay
560ohm 5W - 2x 560 ohm 560R 5W/5 Watt Power Resistor | eBay
CCS with heat shield - 10pcs NEW ORIGINAL IXCP10M45S transistor TO-220 | eBay
FRED - 5 x DSEI8-06A fast recovery epitaxial diode (FRED) IXYS TO-220 5pcs | eBay
Noval Socket - PC3 9-Pin PCB Tube Socket | eBay
Octal socket - zoccolo OCTAL valvole tube valve valvola socket | eBay
Thanks a lot
I wouldn't bother with (most) ebay stuff unless you know and trust the buyer, since you don't know what might be seconds from a manufacturing process or forgeries. This is especially true for semiconductors or capacitors. Just get them from Mouser or Digikey. You get them all together, and you know that they're legit.
Plus you'll probably save a ton on shipping if you get them all from one place.
I am also just starting with a SSE. I am going for quality parts throughout and dont bother with ebay. If you add all the shipping and postage cost i dont think you really save a lot. I got most my stuff from mouser and hificollective in the UK (I have no financial or any other interest in either).
Michael
Michael
The .22uf cap is the most important cap for good sound. I'd be looking elsewhere for that specific cap.
Get some Russian K40 caps cant go wrong there are they are cheap.
Linky:
5 x 0.22uF/ 0,22uF 630V K40Y-9 PIO CAPACITORS. LOT OF 5 NEW CAPS | eBay
These sound good. There's many others but if you want to shop eprey those are the ones I get.
Bob
Linky:
Bob
