Tube rectifier to Solid state Diodes exchange
Joined 2002
The rectification of my Tube tester want to be modified with solid state Diodes like 1N4007, which will last the life of the tester, and avoids the heat produced by the type '83' mercury rectifier valve, which aids both stability and reliability.
Can some body check or made correction on my drawing ???
Cheers Walter
