In a previous posts (well many actually), I have lamented the hum in my Aikido. More recently, some answers to my posts have suggested that my 6SN7s may be contributing to the problem.
The tubes that I have are:
Sylvania 6SN7GTA
Tung-sol 6SN7GTB
Magnavox 6SN7GTB
I have one pair of each tube. This is where it gets weird......if I use an identical pair (eg Sylvania) as input and output in one side of the Aikido, I get no hum at all. I can do the same for the Tung-sol and the Magnavox. If I mix the tubes, even pairing the Tung-sol and Magnavox (same tube type), I get hum.
So, could identical brand and tube types in input and output be somehow acting synergistically in cancelling the hum?
What is the chance that the hum is being caused by my 6.3VAC heaters, even though I have tightly coiled the AC wiring and smashed it against the corner of the chassis? Should I simply invest in a 12VAC transformer and rectify it to give 12VDC - at least then I could chose to use wither 6V or 12V heaters?
Has anyone else experienced this?
Regards,
Charlie
Sylvania 6SN7GTA
Tung-sol 6SN7GTB
Magnavox 6SN7GTB
Regards,
Charlie
I have only tried EH 6SN7s, but I had several that were too hummy in my Aikido. Of the 6 I own, one is terrible, one is moderate, one has just a tiny bit of hum (and sometimes it is completely quiet...comes and goes), and the rest are dead quiet.
Needless to say, I only use the 3 quiet ones and the one with the tiny amount.
I've got 6.3V AC heaters, with a B+ around 330V and my filaments biased up to 90V (so that I don't exceed heater-to-cathode limits).
I'm running them within plate dissipation spec, as well. 5mA of current per section on the front tubes, 10mA on the back tubes.
I haven't found a reason yet, nor a solution. I'm definitely interested if others have similar experience with 6SN7 aikidos....
Jayme,
I got a few more tubes in the mail today. So far, the quietest tubes are my GE and Tung-sol 6SN7GTB tubes. I can even mix them between sockets and channels. I have to try swapping around my Sylvanias.
Tweaker, my heaters are referenced to 1/4 B+ using the 6.3vac transformer's center-tap. John Broskie thinks that maye it is an off-center center-tap, and that I should create an artificial one from the windings using 1% 1K resistors.
Charlie
Charlie
Joe,
I am using the Aikido Stereo Octal PCB. It uses two capacitors labelled C5 and C6. The values that I am using are:
C5 goes straight from B+ to GND and is 2.2uF 400V Wima polyprop. John Broskie suggests 1-10uF.
C6 goes from B+ through two resistors (R15 = 80.6K or 84.5K - I can't remember; R16 = 100K) to GND. It is 0.1uF 400V Wima polyprop. The recommended part value is 0.1uF
The only other caps are on the signal output. I am using (cr*p, I can't remember the value) Auricap. I think that I set the value to filter below 10Hz. I wired them in according to their red/black leads which correspond to outer and inner windings.
Having messed about last night with different tubes, I realize that tube brand and type play a major role. If I use my Tung-sol 6SN7GTB as input and GE 6SN7GTB as output, I get no discernable 60Hz hum, but I do seem to get a very small amount of higher (120Hz???) hum from my righgt channel. If I swap tubes between channels, the hum moves to the left channel, so it must be tube related. I haven't yet worked out which tube is the culprit yet.
John Broskie implied in an email that I should use DC heaters - at least he assumed that I was using DC. He also said that he thought that 12SN7s would improve the bass quality. So, I am now looking around for a suitable 12 rectification circuit. If I go to 12V, I'll simply replace my 6.3VAC transformer with a 12VAC transformer, as they're not all that expensive.
Regards,
Charlie
Regards,
Charlie
Hi:
It sounds like you have some heater to cathode leakage in some of the tubes.
I recommend that you put a 100 ohm wirewound pot across the 6.3 v heater winding and feed the center rotor with about 15 to 30 vdc from the ps. Disconnect the center tap of the heater first!
Now you can adjust for min hum.
Try swapping individual tubes and try to see if the hum follows a tube. That is the bad tube.
Hope this helps
Ed
Hope this helps
Ed
Hello,
I think Ed is right. I have had this problem in 6SN7 tubes in my power amp. If there is any heater - cathode leakage, you will get LOTS of hum.
Your problem seems to be with the tubes and not your circuit / wiring as you state that the hum problem goes to where certain tubes are used.
I think that a lot of people (myself included) get new tubes and automatically think that the fault can't be with them because they're new, but sometimes this is not true.
If it ends up being a leakage problem within the tube, you MUST use DC for the heaters and then you will still get some residual noise unless the heater supply is very well regulated. 12SN7's will be easier to regulate as they take half the current of the 6SN7's.
Either way you should be using DC for the heaters in ANY preamp circuit.
Good luck... Daniel
Good luck... Daniel
Dan, Ed.
Thanks for the replies. I am going to go with DC heaters. I am awaiting the regulated PSU kit from Welborne Labs. I am sure that I could have made this circuit myself, but at this point, it seems that having a printed PCB and kit parts will result in much less stress. Right now, they're having a sale, so I even got 15% off their regular price.
I'll make another posting once I get the DC working.
Charlie
Charlie
My understanding is that the Aikido idea is to cancel out PSU hum actively, based on its top to bottom triodes correlating it destructively. This automatically asks for close to identical triode sections. Hmm a bit optimistic for aligned wires and metal frames in small glass envelopes. It will produce surprises some times. But there must be a solution nearly always. Using a regulated PSU beats the original concept?
Charlie,
I am using about 65-70 volts from my power supply into the center tap of my 6.3 winding if my memory is correct. I believe I used a pot and adjusted it until the noise nulled and then selected a resistor value. You might try this while you are waiting for your other parts to arrive.
Joe
Joe
Joe,
Right now, I am using my Tung-Sol GTB for intput and GE GTB for output tubes, and the system is very quiet. When I look at the test stats that came with my tubes, it seems that these two pairs are not really any more balanced my other tubes. Mind you, a number of folk have suggested that tube stats mean very little other than to the person trying to sell them.
Regards,
Charlie
Regards,
Charlie
BTW: Do you notice any musical difference between the Tung-Sol and the GE, after swapping them in either in the input or output stage?
I've heard that the Aikido is not very sensitive to tube rolling, and I would assume that the cancellation topology might have something to do with that....
cbutterworth,
I am not sure what size of noise cancellation cap you used on the 2nd stage, but I found it should be no bigger than 0.1uF, and the voltage divider resistors should be as high resistance as possible. If not, the tube would oscillate easily due to the slightest imbalance between the two tride sections. This cap although was original designed to cancel noise, I found it have dramatical influence on the sonic perfromance of the circuit. Even more so than the one for the output. As for your low frequency hum problem, it is basically caused by the AC heater supply.
Hello, in frankly, It is never get hum when using 6SN7 with either AC or DC heater if the ground wire to be setted up decently .
In my opinion, if you would like to mix difference tubes with humless as well as same tubes, please try to change the posision of pin 7 and 8 together in 01 tube only, which means to invert the phase of 50Hz noise into 01 tube for vanishing the hum automatically with other tube.
Brgds.
Brgds.
Jtcc,
Excuse my ignorance, but I have two caps on my Aikido PCB, one labelled C6 goes directly from B+ to GND via two resistors in series its value is 0.1uF. The second cap (C5) on the PCB runs directly from B+ to GND, it is 4.7uF.
Viagraless (did you know that it can prevent you from accidentally rolling out of bed???). I expect that your idea of rhum cancellation has a lot of merit. My only problem is that my tube sockets are soldered onto the PCB, so it would be very difficult to change the polarity by swapping pins in one of the tubes. I appreciate your suggestion.
I am waiting patiently for my PSU regulator kit to arrive from Welborne. I could have paid to have it sent fast, but sometimes I need to wait for the US Postal Service (in whom I have great faith - no joke) to get it to me. I suppose that I could have built my own regulator, but after beating myself up with the Aikido, and having a four week baby in the family, I think that I should maximize on my limited sleep.
Anyway, I should soon have DC heaters, and (I hope) totally humless music with any tube combination.
Regards,
Charlie
Regards,
Charlie
- Tubes / Valves
- tube hum in a 6SN7 Aikido - is this weird?
