My suggestion is this made in USA CW switch 16Aac/250V 10,000 cycles at just $4
GTS448F101AHR CW Industries | Switches | DigiKey
Chinese switches typically are 2,000 cycles, though overseas ship in this shop is a PITA.
He said the switch broke - he didn't say how it broke. It could have been that the toggle came off in his hand or some other piece of plastic just snapped.GoatGuy said:So. Just replace the switch with a higher-amperage one. Seriously.
End of discussion in my book.
If it was back emf damaging the contacts then the best solution is not a bigger switch (unless the original was underspecified) but a cap or snubber across the transformer primary.
Its funny how amplifiers such as the Allen model 75 have lasted all these years without a soft start and with solid state rectifiers. I'm curious as to why some think its necessary to either have a rectifier like the 5AR4 or a soft start circuit. We aren't dealing with output tubes needing to be fed heater voltage first warmed up before the B+ is turned on. I don't see anything mentioned that has large transmitter tubes as output tubes that would need heater first followed by delayed B+.
The $4 NKK switch in my picture is good for minimum 25'000 cycles.
http://www.mouser.com/ProductDetail/NKK-Switches/S2A/
I have used these and ones like them for years without failure. I remember when they cost less than $2..
- Tubes / Valves
- Tube amp with no power switch
