What is the IC used in this amp? I will check for you
What is the lowest impedance it can drive?4ohm
What efficiency of speaker do you recommend to use with it?any full range speaker will do a good job
https://www.kit-ya.jp/etc/club/seisaku/ysugi/ysugi35.html
Specification
• Vacuum Tube 12AU7(ECC82)×1
• Input terminal [INPUT-1] 3.5mm (front )
[INPUT-2] RCA jack (rear )
[USB_DAC] (rear )
• Output Terminal [Speaker] Gold plated binding terminal
[PHONES]3.5mm mini jack
• Rated output [Speaker output]
6Ω 8.2W+8.2W、8Ω 6.5W+6.5W
[Headphone] 16Ω 8mW+8m
• Rated input [INPUT-1]170mV[INPUT-2]470mV
• Frequency response 20Hz-25kHz(-3dB,6Ω)
• Residual noise 120μV(IEC,6Ω)
• USB-DAC 32kHz/44.1kHz/48kHz(16bit)
Windows XP or later, Mac OSX or later
Specification
[USB_DAC] (rear )
Thank you, look forward to it.What is the IC used in this amp? I will check for you
