ELEKIT TU-8340 EL34/KT88/KT120/KT150 PULL PSUH AMP on Vimeo
Elekit TU-8340
Semi automatic fixed bias adjustment system
Stock Tube Set EL34 X 4 + 12AT X 4
Options : 6L6GC, KT88, Kt90, KT120, KT150
Another wonderful design by Mr. Fujita.
Max output EL 34 (UL) 41W X 2
(Triode) 21W X 2
KT150 (UL) 50W X 2
(Triode) 28W X 2
Weight 16.80KG
Available in October 2016
Either version of TU-8340 is available in late October 2016. We are accepting orders in advance with a 5% discount prior to launch.
TU-8430 without Tube set $1,250.00
ADD EL34 X 4 + 12AT7 X 4 -------> 175.00
ADD KT120 X 4 + 12AT7 X 4 ------> 260.00
ADD KT150 X 4 + 12AT7 X 4 ------> 450.00
The following upgrade options will be available for TU-8340
- AMTRANS 2W 1% Audio Grade REY carbon film resistor
- Takman TEX 2% Audio Grade carbon film resistor
- Mundorf 0.47 EVO Supreme Silver Gold coupling caps
- Lundalh OPT for TU-8340
Elekit TU-8340
(Triode) 21W X 2
KT150 (UL) 50W X 2
(Triode) 28W X 2
Weight 16.80KG
