noise and distortions
HI.
I have a lot of problem witch my symasym, first of all my configuration:
output stage: toshiba 2sc5200/2sa1943
drivers: toshiba 2sc5171/2sa1930
they should be all original.
power +- 40V, pcb has pretty much the same layout as on project page, c14 5pF.
All other transistors and parts same as in original project.
I don't know is that a big difference I use bd139-16 for bias witch is the version of a hi hfe about 230.
Now the problem.
when bias is set to 0mv(not by setting pot to like 800ohm but it must be set to max 0mV witch is 1Kohm on pot) everything is ok. their is no noise or distortions.
But when i set it even as less as 1mv it starts to make noise (white noise).
when i set the bias on right side about 12mv on the left i have 50mv
so i think the noise came from left side the + one.
all transistor seem fine, I've measured hfe for etch of them and seem ok. but that don't guaranty that they don't make noise.
what i should check first?
the amplifier is mounted on open air, scrubbed to the radiator.
their is no source or even a volume potentiometer attach.
the solider points are ideal I've check them all 2 times, all elements legs are as short as possible.
HI.
Now the problem.
C6 is used to speed up the turn-off of the driver transistors. The amp should be useable without it, but will have higher HF distortion.
You may want to consider using the originally-specified drivers and retain C6. Or perhaps playing with R8 and R7 values (to 33 or 47 ohms?)... Chris or MikeB should be able to give a more definitive answer!!
anatech said:have you made sure that that heat sink is well grounded?.
Yes, it's integral to the chassis. It's hard to track the problem, because it's intermittent. It only happens on the speaker that is farthest from the amps (though cables are same length for both speakers). It seems the common is picking up noise. I can eliminate the symptoms completely by connecting the frame of either of the two woofers to the common speaker terminal. I don't need a DC connection. I can put a film cap in series with the connection, and that works fine too.
Sheldon
Hi Sheldon,
Is it possible you are picking up RF noise? Your speaker lead is another input terminal and may have high impedance at RF frequencies.
You can use an RF LC filter on your speaker outputs, or possibly the input pair needs some additional filtering.
This is when a 'scope is very handy to have around.
-Chris
-Chris
anatech said:Is it possible you are picking up RF noise? Your speaker lead is another input terminal and may have high impedance at RF frequencies.
I know next to nothing about RF, but just the behavior suggests that I'm picking up something in the RF region. It appears that the woofer frame acts as an antenna. I have a scope, and can drag it down to the listening room, but the problem doesn't show up most of the time. As noted, I never hear it with the woofer frame AC connected to the speaker common. Just touching the frame, or even coming within a couple of inches with my hand or head cuts off the interference, if it is present. I suspect that the scope probe would likely do the same.
AndrewT said:The symasym has a full Thiele network on the output.
Have you fitted that?
Yes, built to spec, with boards from an early group buy.
Sheldon
hi again.
I still have problem building symasym, but i have very interesting observations.
this configuration gave me hum and noise but stabilizes when the bias is more then 13mv on one resistor. when i drop the voltage less then 13mv noise comes back and the bias it self gets unstable on minus side i have -10mv but on plus side 30mv but thats oscillations i think. when i set it to stable bias above 13mv the sound is very nice the bass middle and hi all normal no oscillations.
but when i start the amplifier there is a thump and whistle for 1-2sec
drivers: toshiba 2SA1837/2SC4793
the same thing as above
drivers: toshiba MJE15031/MJE15030
Every thing is silent on all bias settings from 0 to 40mv
and theres no noise when turning it on. amplifier sounds normal
all this transistors all original legit
the biggest difference between this transistor is i thing capacitance that what regulates the speed
2SC4793 100Mhz
2sc5171 200Mhz
MJE15030 only 20Mhz big capacitance
with 2SA1837/2SC4793 theres very nice sound much more interesting colorized then with MJE15031/MJE15030.
so i would like to use them but how to stabilize them?
or i have some different problem then just drivers ?
pleas help!!!!
2SC4793 100Mhz
2sc5171 200Mhz
pleas help!!!!
Hi
In order to reduce the gain of 27dB [Av = (R29/R30) +1] - see schematic, and the quality amplifiers that i should lose nothing?
Now gain is: Av = (22 / 0.499) +1 = 45.1, or Av = 33.1dB!
Attention: If the gain is too high because symasym is driven from preamp, R30 can be increased from 499ohms to 1k, but in this case R16/19 (22 or 33 ohms, not on schematic, REs to Q1/2) are required to keep feedback at same level and...
This somehow does not understand?
thanks
thanks
- Troubleshooting your Symasym
