Trinity Tube Heads
AriesMotor Would like to introduce the Trinity Tube Heads to our Asian and Middle Eastern Customers .These High End products are designed and engineered in UK and designed for car audio application.
The source unit plays an important role in trasmitting audio signal. By adding on the Tube Heads,Original signal is processed to Reveal High End Analog characteristics in your car.
These Dual mono Class A Tube Heads should be placed Close to amplifiers.The Tube Heads using 12ax7(low microfonics) tubes are very efficient ,and equipped with tube dampers to tackle most vibration problems in the car.
We carry 3 models
BRAM , VISH and SHIV
Dual Mono Class A
Elegant Black Gloss Fibre glass casing
High End Jantzen Audio Capacitors (800V)
Siltech silver wire and solder termination
12AX7 tubes
For information you can email me at ariesmotors@gmail.com
