Transmission line or TQWT with 2 woofers in 2 way system ?
Martin:
Thank you very much for your response!
Lately, I get asked this question at least once or twice a week.
I'll take your suggestions and try to model it, I'd like to work the #'s before I start cutting wood.
In general (for everyone, not necc. Martin), is the MTM better than a single woofer for reasons of bass and fast response?
In other words, what offsets the complexity of having 2 woofers in a single TL? I'm assuming you get more bass and faster response due to the lighter cone than a single larger woofer (and smaller enclosure width), but is this really true?
I guess that's an MTM question not just a TL question.
frugal-phile™
Joined 2001
The lighter cone/faster response has been beat to death on the BASSList and on the LambdaList and from lurking on those posts i'd say that general concensus is that this is myth.
I like 2 bass drivers in any enclosure because i can load them push-push with the back driver providing brute force baffle-step compensation (back driver can be run all the way or rolled off above the bafflestep [avoiding some of the problems with a regular x.5 way system])
dave
That's really interesting as many high end speakers use this configuration.
To whit on the Thor's though, this implies that a single woofer might be easier to optimally design, and with those expensive Sea's woofers would be much lighter on the wallet also.
Ok, I worked the numbers through Martin's models. I used method 2) above:
Method 2 : Model a composite driver at the average location and set the T/S parameters as follows :
fd = 31Hz
Re = 3.05
Lvc .2mH
Bl = 7.2N/A
Sd=252 cm2
Vd = 74 l
Qed = .39
Qmd=2.5
L = 81 in
Driver Pos = 10.5 in (6+5 from top, but 3/4" mdf on inside)
So = 1.6Sd
Sl = .4 (Sd)
These are from the Thor article posted earlier.
I get the responses below:
I Think it looks OK, comments?
(NOTE: These images may not be here long, please refigure from Martin's Mathcad files if they do not come up! I'll edit the post and rework them if I change the params)
frugal-phile™
Joined 2001
Thanx for those. It is good to see that my gut reaction wasn't far off. The bass extension is essentially none over a sealed box with little terminus output. Might have well stuffed it a little more, cleaned the ripple up a bit more and walk away with just the advantages of an aperiodic line.
dave
Interesting, I thought they looked slightly better than the default, but I'll play with it. (Not sure the default values were right either).
My wife says"Build them already!" :D
Note that Sd is already twice that of a single driver .. but I'll work the #'s and post something tonight.
Stupid Mathcad question - how do you specify square inches? I'm using 1.6 Sd (which is 2x SD of a single driver, so that's 3.2x Sd (real)) which equates out to about 80", the published area. I'd like to enter it directly, but if I enter in raised to 2 I get errors down in the calc's. I used the "Unit" window but under 'area' they have Acres :rolleyes:
I'll rework it tonight and use x * Sd if I can't figure out in**2
