I had a Firefox funeral recently. I have used for years but had a lot of issues with recent builds. nVidia kernal driver crashes on Windows 8 was the last straw. I run Chrome unless accessing one of my corporate applications at work where I need to use Internet Explorer. Chrome is lean and fast - works.
You should be able to measure Idss, gm and noise. .
I know how to test Idss.
How to test Noise and gm?
Really? That sucks.
Mine are supposed to arrive today.
Quite so. But miracles do occur.
They were a great source of imported semiconductors for years and years, so I bought a large amount of them about a year or so ago... NG. I was hoping... but you never know what batch they bought or you get...
Curve tracing is a must. They will meet Idss.
There's a $20 curve tracer on ebay that hooks to ur scope, ought to be good enough. (may have to convert to voltage drive though...)
_-_-
Linear Systems has archived Erno Borbley's papers on testing JFETs and the math for the gm test is in there:
http://www.linearsystems.com/assets... The New Frontier Part 1, by Erno Bordely.pdf
This paper at GA Tech (the late Marshall Leach perhaps) shows a method of measuring noise:
http://users.ece.gatech.edu/mleach/ece6416/Labs/newexp5a.pdf
The noise from a K170/J74 is going to be less than most DIYr instruments noise floor -- under 1nV/Rt Hz -- so you set up the device as a amplifier with gain of 20 or 40dB, a.c. couple it to a low noise opamp like the LT1028 or AD797 and filter the output. (A device like the Quan-Tech 5173 uses a series of steep bandpass filters to arrive at nV/RtHz).
Dennis Colin also had a couple articles in AudioXpress on the topic.
http://audioamateur.com/files/2009/02/colin2993.pdf
You can drive yourself to distraction with these measurements.
claims to have real stock any feed back ? 2SJ74BL PC-TOSHIBA FET- AF DRIVER - BL-ENDING ORIGINAL
Yes, but the table on this page makes me wonder.
Manufacturer = N/A ?
Description = PC-FET- AF DRIVER - Replacement .. ?
I wouldn't trust that.
The 2sj74bl I bought from them were fake. Yfs on the j74s from PacificSemi were all around 8ms. The 2sj104gr I got from them all measured above 26ms.
I think I got the last few j104 of their stock. Measurements were taken with a Peak Atlas DCA75.
I also got fake 2sj107 from hkutsource at ebay. I informed them, with measeurements, that the parts were fake. They haven't removed the listing.
How is the testing going?I ordered a handful of the matches, hopefully they are genuine. Will have them by the end of the week.
- TRANSISTORS NEEDED
