That's a good point, one could experiment with loading resistors on the secondary of the transformer to damp any ringing from transformer parasitics. It shouldn't be a lot of resistance, which is good because you don't want to burden the voltage output DAC with too much load.
Cinemag is an excellent choice as well. I would call them directly - David is a nice person to work with, and will suggest the best xfmr for the application.
What are your thoughts on this transformer? It has an 80% nickel core which I suppose makes it higher grade but at the lower price compared to other Jensen Transformers.
http://www.jensen-transformers.com/datashts/11hfmpc.pdf
Oon
Oon
Yes, there are some snubber threads somewhere on the forum that will help with that. Or you can just aim for a total load on the secondary of 3K-5K ohm. Most voltage DAC chips are happy driving 1K loads. I don't see a lot of ringing with 3-5K on the secondary.
As for nickel, I prefer not going above 50%. There are some things in the DAC output I just don't want to pass. But different people have different tastes.
