Trannies 2x22V/400VA - and A5 Q
Hi!
I soooo close to made a deal for one trannie 2x22V/400V - but even better - maybe I will get 2 of them ...
So: in first case - I intend to use it for A3 (I mean - 4 transistors/channel, no balanced input, ..) ... With little higher PSU voltage but nevertheless ...
But if getting 2 trannies - I'm playing with the idea to build two more A5-look-a-like monoblocks ... OK, a little bit lower voltage than original - but I could bias it a little bit harder - my speakers have nominal impendance 5R - so I guess the extra current will be good thing :D
What do you experts think about such A5 PSU?
Thanks!
MikeW said:
I built an Aleph 3 with 21 volt AC secondaries and four pairs of outputs per channel. Cranked up the bias to 3 amps and it sounds great. It has a C-R-C for filtering and is running +/- 26.5 volts.
Build it you will like it.:smash: :D
MikeW thanks for practical experineces! :D I'm quite sure I will build up one stereo A3 if getting only one trannie ...
But what about my second idea - if getting two trannies - "can" (OK, I know I can - I mean will it be a OK working A5 derivate) I make a sort of mono A5 (I allready have set of 2 mono excelent PCBs for A5) - OK with lower voltage than original - but with higher bias current - 'cause I have enough hetasinks to cool down around 200W/channel with no problems at all ..
As said - my speakers are 5ohm ones - and I guess it's better in my case to have higher current "capability" than voltage itself?!?
Oh btw - the thing is - I have 20 matched irfp240 and a set od two mono A5 PCBs by Kristijan (those I intend to use for A5) and home made stereo PCB for A5 taht was meant for A5 before I've got Kristijan's ones - which can be easilly converted into an Aleph with more/less output devices - so I thought it would be nice to spent those 8 transistors that will be left and rearange the PCB from A5 look alike to more A3 (no balanced input, less transistors) ......
Hmm - a little bit complicated story of mine I guess ... :(
Thanks!
Hehe - good one ;)
Well I think you know what my problem is - with those 4 heatsinks I have there are some problems with stereo chassis - but the trannie for A5 I allready have is only one ...
With those two I could separate it into two chassis and finnaly solve my "engineering problems" with designing the chassis itself ;) :D
Stabist said:
Yeah Leon I agree - more voltage. more bias, more heat ...
But in my case (for A5 mono) - less voltage+much more bias-->I hope more heat and better sound ;) :D
On your place I will try this. Why not ? More bias current, more speaker control and not much dissipation, becouse of lover power supply voltage. You have everything to make Aleph 5 to work, and test how it works with diffrent supply voltage and bias. Then make a decision what chasis will you build.
That's another point of view - to experiment with differenr setups, yes ...
Well - I just can't decided between a chassis looked like this ...
