Great news, thanks!I just got word that the amps will be completed and shipped to me on Jan 17. This is good news.
Yes, they ship out tomorrow (Monday). I am packing them today. I will include the heat transfer block and your choice of TH or SMT BTSB PCB for the buffer (no SE out). Plus I am including a complimentary set of connectors to allow you to get started quickly with connecting to your project. Molex MiniFit 4pin for PSU connection, Molex MiniFit 6pin for speaker outputs, qnty 2 Molex KK 3 pin for Bal audio input, qnty 1 Molex KK 2 pin for external 15vdc supply. Note that the Molex KK crimp pins are ammo reel type (I ordered by mistake, loose ones much easier to use). But you will have to cut them off the ammo tape with cutters. Hope that’s not a problem.
If you want an LED connector and reset switch connector, you will have to get your own Molex KK 3 pin and 2 pin separately.
Thanks for your generosity with the connectors. I already received my Micro Audio SMPS630-S0 power supply. I’m pumped to build this amp!Yes, they ship out tomorrow (Monday). I am packing them today. I will include the heat transfer block and your choice of TH or SMT BTSB PCB for the buffer (no SE out). Plus I am including a complimentary set of connectors to allow you to get started quickly with connecting to your project. Molex MiniFit 4pin for PSU connection, Molex MiniFit 6pin for speaker outputs, qnty 2 Molex KK 3 pin for Bal audio input, qnty 1 Molex KK 2 pin for external 15vdc supply. Note that the Molex KK crimp pins are ammo reel type (I ordered by mistake, loose ones much easier to use). But you will have to cut them off the ammo tape with cutters. Hope that’s not a problem.
Hi Pete,
Glad you got your amp. Know that each was individually tested and playing music before I shipped it.
Sorry, the “manual” is still being written. In the mean time, you can use the video plus the diagrams for the dip switches and jumper settings here:
https://www.diyaudio.com/community/...ign-class-d-amp-with-pffb.372379/post-7254890
I've just ordered and received a bcp (REV002, 03 2020 JPS64) without components. I was wondering if there's any easy workaround around these components:
LM5010ASD/NOPB
LM2940IMP-12/NOPB
As they're out of stock everywhere I looked. Also, the TPA3255DDVR is sold out, but TPA3255DDV is not. It seems to be the same thing, isn't it?
Thanks & Regards,
LM5010ASD/NOPB
LM2940IMP-12/NOPB
Thanks & Regards,
- Group Buys
- TPA3255 Reference Design Class D Amp GB
