Those capacitor are for charging gate drivers for different audio signals(various bandwidths) and those work on 12v or 5v supplies depending upon the tpa32xx you use. So a 25v cap is enough.
No need to provide additional supply. You will just fry the board. Bst means bootstrap. You can try on any ab class ic to see what it does which has a bootstrap cap. 😜
I have a BDM8-A TPA3255 and I am powering it with a 48 volt switching power supply. The round rocker on /off with a LED switch I was using in the chassis blew probably because it is not rated for 48 volts. I have the LED in the switch powered off of a voltage step down thingy. What power switch should I use? I have been looking to find a switch but most everything is rated for 12 volts. I did find one that was rated to 30 volts.
My switch worked fine for a year at 27-36 volts with another amp board. I guess 48 volts was just to much.
Thanks Scott
Thanks Scott
Switching DC is problematic due to arcing. So normal switches may not last long.
You can try a solid state switch as it does not care about arcing :
https://sound-au.com/articles/mosfet-relay.htm
Otherwise, better to put a switch on AC mains line.
Guys,
Taking into account that TPA3255 can take max 7 Vpp at the input.
If one has the exact TI evaluation board schematic and applies the PFFB implementation as described in TI application note, how does this affect the maximum voltage signal you can feed the amp so that the chip still receives max 7 V pp?
Im running this board. Its of good quality and powerful.Intresting dual 3255 board
https://a.aliexpress.com/_mPyYgpS
- Class D
- TPA3255 - all about DIY, Discussion, Design etc
