TPA3122
i have made this pcb layout for TPA3122 would like to know how it is,, i know its not smd but some reasons are the reasons for me to use axial components
There's a number of problems I see right away. First of all /SD and MUTE are not connected to anything. You also have ground traces wandering around instead of having direct paths to pins. Your PVCCR/PGRNDR power cap is hanging off the board. I'm assuming the two caps from AVCC1/AVCC2 to ground are a mono cap and a power cap, not two mono caps.
Try to make your paths as direct as possible. Don't have your ground traces circle all about. Start with a ground plane, then subtract from it for the other traces. Work with a netlist -- don't try to do things by sight (especially important for beginners).
