The datasheet preconizes to ground the IC via the thermal pad . The pad is on the upper side where the heat sink sits upon either with silicon paste or glue . How to link electrically the pad to the heat sink ? 2x7 amp can pass through .
Sorry I posted wrongly on this forum instead of classD can it be moved , if you please.
