Tony's latest traffo DIY build
hi tony thanks for the reply,
i cant find 1 3/4 center leg lamination, they have 3.8cm(1 1/2inch) center leg,so transformer height is 3.75inch. is this ok tony for my post no 198?
pls give the specs.
1.5 in centre leg x 3.75 inch stack....
VA = (1.5 x 3.75 x 5.58)^2 = 985.2 volt-amperes
primary current = 4.28A
primary turns = 1750/(1.5x3.75) = 311 turns #19 awg.
secondary turns = 42 turns #16 awg
you need 4 coils of 42 turns, in series to get 60-30-0-30-60.
hi tony is this correct or not?
total secondary voltage is 120v ac(60-30-ct-30-60), 10ampere. so 1200watts.(VA).
if i select 1444w, size lamination (3.8cm-10cm) in the below table.
turns per volt 1.1.
for 10ampere table shows 13awg so 120*1.1=132 turns for secondary.
for primary 1200w / 235=5.106ampere. so 235*1.1=258.5turns.
16awg 5.106ampere
HELLO
Hi Tony
greetings thank you for guiding me to make my torriod
OD 21cm ID 10.5 cm height 10cm
primary 13 swg
secondary 11 swg
ac 50 0 50 and 60 0 60
apex audio your softstart is good have to change 47 ohms to 50 watts
nice softstart
warm regards
andrew lebon
hi tony,
nice work on those trafo... and you really help alot of diy'ers out there.
btw, im also a newbie and need some advice from you...
1. i have 2 trafo from a friend with the same size in Height of 72mm and
Width of 86mm.
2. but different thickness. the 1st has a thickness of 44mm and the other
is 41mm.
now, one of my friend says i can merge this trafo to be more effective.
is it possible?
thanks.
Hi Tony
primary 13 swg
secondary 11 swg
nice softstart
warm regards
andrew lebon
nice job andrewlebon,
which softstart are u using? can u share it?
how many ampere of the torroid.
