TO-247 insulator from a TO-3
I could not get TO-247 mica insulators from Mouser or Digi-Key, and didn't want to use some kind of sil pad thing-a-ma-jig, so I looked at a TO-3 insulator. I had one that could easily be used, it was large. But it was the exception. Most TO-3 insulators, such as the ones I got recently, are cutting it close.
And yet I believe they will work. I bought 10, and modified them all. The last ones were best, and the first attempts were not quite good enough.
I used sharp scissors and a drill press with a 1/8" bit, drilled off-center from one of the lead holes. There is not much 'wiggle' room - if the insulators are too far to the right or left, the metal on the back of the transistor will be exposed to the heatsink surface directly.
I have cut them so that if the tops are parallel with the top of the transistor, they're aligned properly. The holes through which the screw must pass are just large enough to allow a #8 screw to pass. I used a small needle file to gently enlarge them, otherwise, the screw, when turned, engages them.
Started out with this :
a clever bit if re-engineering.
Are you able to confirm if the larger To264 will fit?
In view of the space still available is there room to rotate the To247 downwards and fit a second one in the upper gap.
What size is your No.8 thread?
I find that No.6 fits, but not No.8.
For drills I would use 3.25mm or 3.3mm or a No.30
To247 pads and micas fit To264.
But you do need to centralise them accurately without a twist(rotation).
There is just enough land to see the pad hanging out all round the metal conductor .
I found that sticking the pad to the transistor made it easier to keep the registration while fitting.
I'm not sure about TO-264 - I would guess that wouldn't work - but not sure.
There is only room enough for one transistor per insulator - and that was cutting it close.
The screw was #8, 24 thread. Of course, a 32 thread would work also.
The 1/8" bit seemed to be the perfect size - all I had to do was file it a wee bit with a little needle file.
No, no problem cutting it at all.
I was surprised to be able to get away with drilling - but it is possible also.
I could almost swear Mouser and Digi-Key had the TO-264 - but not sure. They seemed to go out of their way NOT to have the TO-247, though.
I would happily buy a a TO-247 from Mouser or Digi-Key if I could find one there - I just don't want to use some sil-pad.
JFTR:
there are 4" x 4" mica sheets, which are even very economical.
I've used those sheets to make MT200 style insulators for Sanken and Toshiba ring-emitter devices, as readymade insulators could not be had overhere or were pretty expensive.
Punching holes for screws/bolts is also quite easy.
Finding aluminium oxide insulators for MT200 is much more difficult.
Retired diyAudio Moderator
Joined 2002
insulators
I prefer the thick aluminum oxide insulators, and haven't had any issues using them. Mouser sells them:
TO-220
Part number: 532-4170
3,447 in stock
Pricing:
1-9: 0.40
10-99: 0.35
100-499: 0.30
link
TO-218/TO-247/TO-3P
Part number: 532-4180
6,703 in stock
Pricing:
1-9: 0.70
10-99: 0.63
100-499: 0.53
link
The TO-220 size actually works well for TO-247 devices:
(the metal portion is entirely covered by the insulator)
I used the TO-220 size once for TO-3P devices, as Mouser was out of the larger ones. This was my friend's amp and it has worked fine for many years, but I would recommend using the larger ones if we had been able to obtain them at that time. Pic:
http://www.briangt.com/gallery/albums/jeetamp/Resize_of_amp_016.sized.jpg
Mouser has no min order quantity for their site, and shipping is reasonable.
Brian
