They are pushing the '1738, but if you look at the difference in cost, well........draw your own conclusions as to which one sounds better.
The '1738 does have current output. From what I have been told, it is not much different than other delta-sigma types, except that they allow you to use external components to create the voltage output. The other types perform the I/V internally, and the voltage outputs are summed externally.
Jocko
Jocko
I have one, as soon I get a pcb I´ll tell you more!
According to the datasheet it combines the advantages of a multibit converter with that one from a sigmadelta.......???
The only thing I can say is that it would be heavy nonsens to convert the voltage output of a real sigmadelta to current only for convert it outside to voltage.....
yes, it´s a PCM1738...... Waiting for the PCB´s..... Hope they work, you know SSOP isn´t the best to solder and to etch....
I will test it only with the standard application, should mean no hypermega OP627 or tubes, only NE5534. Currently I´m only able to test it at 16bit/48kHz (cs8412)
AND: I have no comparision to other good DAC´s, currently I have PCM1716, WM8716, AD1855, TDA1541(standard) to wich I could compare it.
It´s EAGLE format, f you don´t have it download it at www.cadsoft.com
plz don´t forgett it´s only a urly prototype....
skaara said:And what are the other good dacs of TI?
Im just about to build a few PCBs for a DAC based on the PCM1730.
The stats look impressive... ill soon find out if it is.
lovely screwclamps.....
I know, - but I really love Screw Clamps sooooo much! No, in fact I wouldn´t really mount a screw clamp, it´s only......
the matter why I didn´t made a solid ground plane is my printer....
but the hole board isnt´designed to bring me performance, since i´m a rookie in area of Digital-Analog Converters. Moreover it should be a solid platform for avaluatiin the hole thing...
But I would like to thank everyone who give me advices in terms of performance.
SSOP28 to DIP28
My E-mail address is:
50140834@alumni.cityu.edu.hk
Please tell me how many PCB pcs you want?
I will send the header include the PCB.
I will send the photo to you to see my DIY SSOP-DIP28
nFORCE.
nFORCE.
- Digital Source
- ti dacs
