hi all
i used formulas from steve bench's site on my operating point for a 300b tube, 3k output transformer, used in a SE amp.
operating point for 300b:
Vp-k: 300V
bias: -59V
Ia: 80mA
the figures are approximately :
Po at 6.77W, 8ohm and 13.53W, 4ohm.
HD2(%) 5.322580645
HD3(%) 3.548387097
HD4(%) 4.35483871
are the above acceptable values, given my operating point?
care to share your 300b operating points?
thanks.
rgds
garbage
Vp-k: 300V
bias: -59V
Ia: 80mA
HD2(%) 5.322580645
HD3(%) 3.548387097
HD4(%) 4.35483871
thanks.
rgds
garbage
Let have a look at the operating points KWY suggests
http://www.diyaudio.com/forums/showthread.php?s=&threadid=42477&pagenumber=1
i've no idea really. i calculated with the formulas on steve's site.Geek said:The OPT Z sounds about right, but why on earth so much 3rd harmonic?
thanks, i read your thread previously.Antonio Tucci said:Let have a look at the operating points KWY suggests
i noticed he suggested 350V/60mA/5K load with 74V Bias. but that is with 5k load. i am using a 3k load. drawing load line for 5k load and 3k load will differ, resulting in different parameters.
did some more accurate calculations
i did more precise calculations of the loadline at 300v, -59v bias.
the 300B loadline looks like this:
giving values of
Va : 83.63 V
Ve : 474.54 V
Po : 6.37W, 8ohm or 12.73W, 4ohm
Current at 0 volt grid bias
Ia : 152mA
Current at half the quiescent bias voltage
Ib : 109.2mA
Quiescent Current
Ic : 80mA
Current at 1.5 times the quiescent bias voltage
Current at twice quiescent bias voltage
Ie : 20.71mA
THD(%) : 4.840429583
HD2(%) : 4.952205309
HD3(%) : 2.309210868
HD4(%) : 3.105356122
calculations taken from Steve's Tube Pages
an excel file of the calculations can be found here:
giving values of
Va : 83.63 V
Ve : 474.54 V
Ia : 152mA
Ib : 109.2mA
Quiescent Current
Ic : 80mA
Ie : 20.71mA
