This is not just another gainclone
Peter Daniel said:
I didn't want to give a customer a reason for a doubt if I used BG or not.;)
BTW, my acrylic GC has the caps skinned, but the first one also didn't and it sounded better.
So you remove a thin layer of plastic from the caps and then put the whole amp inside a block of........PLASTIC:eek:
could that be why it sounds bad:idea:
There are plastic and plastics. It's not that it sounds bad, it just doesn't have that extra touch. One way to get to know, is trying different things. What if it would sound better and I would've never tried it?;) So don't blame me for that.
Here's another pic. Proper light and tripod makes also things look different.;)
Peter Daniel said:
And that's my first finished GC. This one goes to Europe.;)
Peter,
I think you mentioned it before but don't know where. Any chance of telling me where to get them knobs you're using? I've been looking for something at my normal suppliers but have come up with nothing nice.
Really nice work otherwise. I just finshed the mechanics of my first GC pair in my workshop which consists of my kitchen table, fridge and any availably floor space. I've got aluminium shred in every carpet today. I see that the available tools make a difference in the end result (inidividual abilities matter too, to my disadvantage it seems). Really nice.
Bridge over trouble balance...
Hi there,
Very interesting thread indeed. And beautiful too, thanx to Peter ;) .
I've read the thread all along, but something still puzzles me... Sorry if the question seems absolutely dumb, but If the GC is used in an "inverted" configuration, thus the amp is an inverter, I still don't understand why the "+" of the speaker is not connected to GND while the "-" is tied to the chip's output. This is done in the Zen design, but not here... Am I totally :crazy: ?
Apart from this, I've had a little idea for combining balanced input and more power... As bridging means having two signals of opposite phases, why not trying to use both signals of a balanced line to drive two amps, and connect the speaker between the two outputs. I've attached a little drawing of the idea. Is it worth testing ? Feel free to flame or praise :cool: . Notice that I didn't mentionned the polarities of inputs and outputs, since I don't know the answer to my first question ;)
Re: Bridge over trouble balance...
CheffDeGaar said:
Hi there,
question ;)
In the pictures it is not but it is of course up to everybody how they connect their speakers. Just like my Zen R I do connect the speaker in absolute phase on my GC. Why would one not? Lots of people are picky about absolute phase and want switches for phase on their pre-amps but in this particular thread it is often neglected. I did ask the same question as I felt it justified but the reply then was that there was no need to be anal about it. I just can't see any reason why one would not at least aim at correct phase as the work involved is nonexistent (solder 2 cables one way instead of the other way...). I say do it..
http://www.diyaudio.com/forums/showthread.php?postid=76588#post76588
This is really interesting.
I want to buy LM3875. But don't know where to buy just that one here in Sweden. Any ideas Svedalaboys??
I can find the LM3886 for about 10$ here. But want to go with the other one.
Unless you advice me otherwise ;)
I think i'm gonna do the minimized gainclone from peter.
Been out of the buisness of diy amps for a while (A thousand other project running at the same time)
/Patrik
RS Components have them *all*. Only thing though is that you can only order items in stock if you're not a company. I use my dad's company for the ordering and then I just pick up the invoice and pay it which gives me full ordering possibilities.
The RS prices are also much better for these parts than for instance ELFA. LM3875T is SEK 75/USD 8 at qty 1 whereas ELFA is SEK 115/USD 14.
Turn-on/turn-off DC transient
Has anyone investigated using the gainclone as a tweeter amp in a bi-/tri-amp arrangement? I'm currently playing with one that is capacitor-coupled at the output, but due to the transient protection circuitry I am very tempted to run it direct-coupled.
The National datasheets do not provide any parameters for the protection circuit. I do not have access to a scope capable of measuring the turn on spike. Is there anyone who does?
Disabled Account
Joined 2002
The amp inverts phase indeed Peter, after all this topology is called an inverting amp. So reversing the speaker connections does make sense when one emphasises on absolute phase. It may come handy in case you use a non os DAC. Both devices invert and absolute phase will be correct again. This can possibly be a stimulation to build a Kusonoki style DAC :nod: Just don't say it was me that made you do it !
Jean-Paul :wave2:
