Thermistor: 1K TD5-C210/Adcom GFA-555
Joined 2011
It's connected between the base and the emitter of Q621, which is the NPN "driver" transistor that drives the bases of the four parallel NPN output transistors on the high side. Interestingly there is NOT a thermistor from base to emitter of the PNP driver transistor that drives the bases of the four parallel PNP output transistors on the low side.
See post #32 dated 14 October 2011, of the thread "Adcom gfa 555 help", for schematic.
The thermistor is (was) glued on top of the driver 2SD525 and connected to its emitter and its base. I'm replacing the drivers with MJE15032/33 but need a new equivalent thermistor.
See the highlighted section on the schematic (attempting to attach)
Rgds
Mayank
  • GFA-555 Schematic.pdf
I think that this NTC isn't critical at all wrt the drivers, despite it's position in the schematics. Electrically, it relates to the bias spreaders Q10 and Q9, reducing bias voltage with increasing heat sink temperature. So you'll just have to look for a new 1k thermistor.
Best regards!
Confirmed!
I have just installed and tested these in a GFA-555 MK1. I used the 3% tolerance part instead of 5%, as that's what Mouser had in stock.
Part number
B57164K0102J000
in stock at Mouser and Digikey.
Bias level versus heat behaves pretty similar to the stock thermistor. If I connect the amp to a dummy load, and heat it up to 80C, I get about 80mV in bias current. Remove the signal and it slowly drops back to 16mV.
Confirmed!
Part number
B57164K0102J000
@Phloodpants What do you use in place of the original factory adhesive to get a secure thermally conductive bond between the thermistors and drivers?
