Hi everyone.
I hope you don't mind but i just wanted to share my first hi-fi diy project with you guys.
It's a PPA headphone amp, with a small troid and Velleman psu. A realativly simple project from the electrical perspective. The chassis is however something that i'm very proud of.
I currently have 4 of brianGT's boards in my sweaty hands. These will go into a similar chassis, as will a PC with RME souncard and Behringer DCX2496. I'll then have the bi-amped system that i've been craving.
Lot's of work to do yet though....
Cheers
Cheers
cedus said:Wonderful chassis
Can you give us more details on how the chassis is built ?
It started with a simple idea to build a home theatre PC. I wanted to use a Griffin Powermate like this
I had 4 front plates waterjet cut from 10mm ali, but shelved the HTPC until a suitable motherboard could be sourced (i've finally tracked down what i want so stay tuned for that). All of the other pieces i've made myself. I had 1 length of copper pipe, 1 length of ali bar, a little bit of plate and a small piece of ali sheet. having a lathe really helped.
It's the feet i'm most happy with.
peranders said:Indeed good looking!
You don't have picture of the inside?
Here you go, nothing special...
- Chip Amps
- There's no stopping now.....
