The Well Tempered Master Clock - Group buy
Interest list:
- andrea_mori: 1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-EXO + 2 x TWTMC-DRIXO-XFMR + 2 x TWTMC-EXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp
-hifoli: 1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR
Edit: added transformer kits, thanks for the hint andrea
Note on combining order
Please, keep in mind that to build yourself the new DRIXO, EXO, PXO and DBM if you buy the bare PCB you need a set of RF transformers (3 pcs for the DRIXO, 4 pcs for the EXO, 3 pcs for the PXO, 2 pcs for the DBM).
We have choosen Mini-Circuits devices and we cannot guarantee that XO and Doubler will work correctly with other transformers. Almost all the choosen Mini-Circuits transformers have a MOQ of 20 pcs each type, so I suggest to get them via the GB, otherwise you have to order a bunch directly from the manufacturer (Mouser or Digi-Key don't supply them).
Interest list:
-laserscrape: 1 x SC 22.5792 MHz + 1 x TWRPS-UGL + 1 x TWTMC-DRIXO + 1 x TWTMC-DRIXO-XFMR + 1 x TWTMC-STS-SX
Interest list:
-Markw4: 1 x AT 22.5792 MHz + 1 x AT 24.5760 MHz + 1 x AT 45.1584 MHz + 1 x SC 22.5792 MHz + 1 x SC 24.5760 MHz + 1 x TWTMC-DRIXO-F + 1 x TWTMC-PXO-F + 1 x TWTMC-DBM-F 22/24MHz to 45/49MHz + 2 x TWTMC-STS-SX + 1 x TWTMC-DRIXO-XFMR + 1 x TWTMC-EXO-F + 1 x TWTMC-STS-DX
Interest list:
- mksung: 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 2 x TWTMC-STS-DX
Update
Interest list:
-hifoli: 1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 2 x TWTMC-STS-DX
Warning
The new DRIXO and EXO don't work with SC-Cut crystals at 45/49 and 90/98, they are designed to work with SC-Cut crystals from 5.6448 MHz up to 24.576 MHz.
If you want the SC-Cut 45/49 and 90/98 MHz to work you need the old Driscoll design (Emitter coupled TWTMC-D), or better you can start from a lower frequency suitable for the DRIXO and EXO oscillators and then you can implement one or more frequency doubler TWTMC-DBM (suggested).
Interest list:
- mksung: 1 x SC 22.5792 MHz + 1 x SC 24.5760 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 2 X TWTMC-DBM 22/24 MHz to 45/49 Mhz + 2 x TWTMC-DBM-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 2 x TWTMC-STS-DX
Interest list:
- Sligolad: 1 X AT 5.6448 MHz + 1 X AT 11.2896 MHz + 1 offAT 22.5792 MHz + 1 off AT 24.5760 MHz + 1 off SC 5.6448 MHz + 1 off SC 6.1440 MHz + 1 off SC 11.2896 MHz + 1 off SC 12.2880 MHz + 2 off SC 22.5792 + 2 off SC 24.5760 + 2 off TWTMC-DRIXO + 2 off TWTMC-PXO + 4 off TWTMC-DBM + 1 off TWTMC-DRIXO-F + 1 off TWTMC-PXO-F + 1 off TWTMC-DBM-F + 4 off TWTMC-DRIXO-XFMR + 4 off TWTMC-PXO-XFMR + 4 off TWTMC-DBM-XFMR
To clarify about Sine to Square converter layout (SX/DX types)
Interest list:
- wlowes: 1 x SC 5.6448 MHz + 1 x TWTMC-DRIXO + 1 x TWTMC-DRIXO-XFMR
Interest list:
- mksung: 1 x SC 22.5792 MHz + 1 x SC 24.5760 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 2 X TWTMC-DBM 22/24 MHz to 45/49 Mhz + 2 x TWTMC-DBM-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 1 x TWTMC-STS-DX + 1 x TWTMC-STS-SX
Interest list:
- Audio curiousity: 1 x SC 5.6448 MHz 3rd overtone 15 73,00 + TWTMC-DRIXO-F New Driscoll XO (without crystal) 120,00 + TWTMC-DBM-XFMR Frequency doubler transformers kit 21,00 + 1 x 11.2896 MHz TWTMC-PPG New Pierce entry with HC-49/U crystal 22,00 + 1 x 6.1440 MHz TWTMC-PPG New Pierce entry with HC-49/U crystal 22,00
Interest list:
-hifoli: 1 x SC 5.6448 MHz + 1 x SC 6.144 MHz + 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 1 x TWRPS-UGL + 1 x TWRPS-pp + 1 x TWTMC-STS-DX + 1 x TWTMC-STS-SX
Interest list:
- minionas: 2 × TWTMC-DRIXO-F + 2 × TWTMC-DBM-F + 2 × TWTMC-STS-SX + 1 × SC 5.6448 MHz + 1 × SC 6.1440 MHz
Interest list:
-tonerei : 2 x TWTMC-DRIXO-F + 1 x SC 22.5792 MHz + 1 off SC 24.5760 MHz
Interest list:
Cerole: 2 x TWTMC-DRIXO + 2 x TWTMC-DRIXO-XFMR + 2 x TWTMC-DBM + 1 x TWTMC-STS-SX + 1 x TWTMC-STS-DX
