They better ask me before proceeding to something final, because there are details and options.
It's a looong way.
This will be - for me - the 3rd or 4th version of a PCB (I'm a toner-transfer guy) based on your schematics, all working flawless.
But that's another story, the v1.2 (as correctly Massimo pointed out, as per post 1893) need a more attentive job, not only a matter of not crossing lines as I previously did. Anyway, thank you in advance for your kind offer (and for sharing your fantastic job!)
Guido
Almost finish my Lastest Layout (D-1 with Salas Shunt Reg in one board).
PCB is Ready for now.
How is the progress with the D1 with the shunt reg? Will there be a GB?
Hi Salas, lauret,
Would you have any more info/ link to where this "D1 + Salas Shunt Reg" can be found, please?
Click on the arrow in the crt quote to jump to the post from crt.
Rs
Thanks Salas, solved the Rs problem, now the reg. is going on perfectly, a photo just for fun:
Hi All
Is a long and fantastic good thread. I have been browsing at the attachments
Please tell me how to set the CCS with leds and with transistors.
200mA is to much for my need
This my first post in this thread
Thanks to all
Audiohifi
Read a bit from the start. Its been explained many times. Rule of thumb for the 3 leds ccs schematics I=2.2V/Rset very roughly.
Rs first impressions
Wow, really it's a great step forward the Rs setup, it's like you drive a formula 1 car, all is plenty of extra power, fast, dynamic, very, very clean.
I really recommend fo everybody to do the up-grade to Remote Sense, it's easy to do & you get a lot of more "good sound" than the work done.
Congratulations Salas & thanks again to share & help us.
- Power Supplies
- The simplistic Salas low voltage shunt regulator
