Hi Leeuwarden,
You need the internal resistance of the coil not the load impedance.
Gr.
Ronald, Amsterdam.
Thanks, I'll see if I can find that somewhere...
The internal resistance of the Blackbird is 135 ohm, I do not think there will be much difference between the internal resistance of Blackbird and Bluepoint special etc. I think a resistor of 120 or 150 ohm (instead of the 47k you calculated) will do perfectly. This resistor balances the two inputs of the op amp.
OK, I just got my resistors for the above Phonoclone and have another question. For R1=135, should I undershoot with a resistor value of 121ohms or overshoot with 150ohms? Same thing for R2=540, under at 511ohms or over at 562ohms. Thanks in advance.
Dave
Here is my earlier conversation with Richard. I would order one set over and one set under as the exact values are hard to source.
One thing I did is to solder sockets 1-1571994-0 Product Details - TE live these into the resistor holes on the board. That way I could try different ones out or go back to stock vales if I wanted to try a LOMC cart. Just cut it apart into single sockets and solder them in. I'll see if I can find a picture of what I did to clarify.
Great minds think alike ... I use them too. Unfortunately they are rather small for more some of the more exotic resistors which has a thicker lead. Do you know if there's a version with bigger socket hole?
- Analogue Source
- The Phonoclone and VSPS PCB Help Desk
