The Pass Pub: The High-End Off Topic Thread
Joined 2006
He only allows himself to be seen when you have drunk enough poteen (potato moonshine)........at least he will speak - the pink elephants here in Scotland refuse to utter a word. My o My it can be lonely here.
Here is a pic of the "jogging horn"
Joined 2006
Stick to the roads - don't go into the moor's lad..... :eek::eek::eek:
(Papa goes nuts when the threads to the the werewolves) :cool:
Ooh white lemonade, I haven't had any in a long time, last time I did I went blind - that's when I met my wife, I have been told that my eye sight will improve if I take the forks out of my eyes, Ive seen the wife once, the forks are staying:D
Official Court Jester
Joined 2003
@ZM - Sales Enquiry....
I am moving back to Ireland...Do I get a better discount there than in Great Britain??:p:p:D
Now here is a real heatsink for really fast amps. And the second pic is the portable jogging horn with the one-man-band which didn't turn up to rehearse!!:cool:
well , I'm pretty avare that Every Sperm is Sacred , it doesn't mind is it from Olde E. or Across the Bridge Where Angels Dwell ......
you know - you're more than welcome to share more pics and stories from time spent with Be ........
I still take a look ,from time to time, on his wine + jfet + mosfet + iron recipe
Joined 2006
I've worked on RADAR systems that were smaller than that!!! I like the crazy way you have managed to incorporate the design as a support for the rafter running across the room as well - very ingenious!!! :D:D:D
What material is the "horn flare" made from???? Looks like paper mache or some type of formed sawdust particles bonded together.
mario,marco,eugenio,bei in the photo - hmmmmmm - not Irish names that I am familiar with...... Other than on St. Patrick's day when everyone is Irish!!! :rolleyes:
........I like the crazy way you have managed to incorporate the design as a support for the rafter running across the room as well - very ingenious!!! :D:D:D..........
In fact - if you looked carefully enough you would have noticed - that beam is bearing on two external pylons and that the speaker system is thus suspended from the beam giving a fully floating speaker system! disconnected from the listening room except by signal wiring!!!;););)
I had a system based on the hovercraft principle ... another failure as I failed to allow for the fact that the required thrust required x2 RR Merlin engines which produced some 220+ Db just to keep steady hover position. As for the "Sweet Spot" that was some 8.5 miles away.:D:D:D
Of course the now redundant Harrier VTOs :cool:were then too busy in air displays and they wouldn't let be borrow a couple for experimental purposes.:p
