Started to order parts for F5 Turbo v2, two questions
Hi: I built the Buffalo 3 se kit succesfully, so I think I can get into this project. Most of my diy experience has been with tubes though.
So two basic silly questions: Antek 600 va 24 v secondary ok? I kind of read in the thread that these might not really be to spec. And, do the diyaudio store circuit boards come with standoffs? Thanks.
Backpanel parts kit has standoffs for amp pcb, as well as a lot of other parts that bit the chassis --
Back panel parts kit plus PCB / Transistor / Diode mounting parts kit – diyAudio Store
600VA 24+24 Antek was used for the build guide, it worked perfectly!
Actually working on it today.
Need to make new PSU so the photos are conforming, waiting on a bit of editing from Papa, and I realize I need to take a new set of photos to make things look totally consistent.
When will it be done? No idea, but hopefully soon.
Thanks for the update.
Hello, I have a pair of F5 pcbs layout from CViller laying around (v1.0 dated 2008-12-14). Together with a pcb for the PS.
Now I wonder, are these still worthy of building, given the many new turbo versions? I would be satisfied with the 25 watts of the original F5, so that's no reason to go to a newer layout. But how about the sound, are the turbo version better sounding?
And of course, what about the build guides, are they of any use for the classic F5 (couldnt find a similar guide for the classic F5, except for the 1500+ pages F5 thread...)
Build the F5 with your PCB. The F5T just have more power, there isn't an appreciable difference in sound.
There is a F5 build guide, but it's using the Peter Daniel PCBs. Much of the information is still applicable, as the only real differences are the board layout - it's the same amplifier, after all.
A standard F5 does not need matched transistors, although matched Jfets do help keep everything else in line.
Matched Jfets will return to the store someday. The rest you can buy from Mouser.
F5 guide - http://www.diyaudio.com/forums/pass-labs/188691-illustrated-guide-building-f5.html
But the Aleph j and F5t require matched MOSFETs, right? Would you be interested in doing a quick "build guide" on matching MOSFETS? I've read the Pass articles on it a few times and still it doesn't quite click.
Go to this page, select 'device matching' from the side menu, scroll to Mosfet matching. I can't make a direct link due to the way the pages are formatted.
It's very easy - PSU, resistor and DMM.
The β22 stereo amplifier
Thank you! That is exactly what I needed. That setup is in the Pass article too, but the article goes on up a few levels in complexity, and lead me to believe i needed to too (kind of like when his amplifier articles show a simplified then a full circuit, you don't build the simplified one)
- The diyAudio build guides
