Hi all, I wanted the schematic class G amp,please send to my email at asuservice@ymail.com,thanks all
Hi all, I wanted the schematic class H amp,please send to my email at reza_mir7@yahoo.com,thanks for help
g class amplifier
hi workhorse
greetings have you any schematic of a g class amplifier.
power output 1200 to 1400 watts in 4ohms load with
easy to find parts .
thanking you
http://www.diyaudio.com/forums/images/icons/icon5.gif andrew lebon
hi workhorse
thanking you
dear sir
greetings thanks for your reply i make amplifiers only as a hobby no sale
just to learn and gain knowledge please can you tell me some books on h class amplifiers
to get an insight how h class works
1 where do you get your parts from as h class parts arevery hard to get.
2 do you have a shop in your city as i visit your city often wish i could see the great
workhorse i admire your knowledge
thanking you
andrew lebon
thanking you
andrew lebon
dear sir
thanking you
andrew lebon
Hi Andrew,
Class-H is not covered by any text book yet. You can learn a great deal by experimentation and also by glancing on various schematics. Parts availability is a problem in India, we source our parts from Delhi for samples and sometimes from abroad.
regards,
Kanwar
Hi Kanwar, i have a quick question for you if you don't mind
You mention the switching glitches on the output when rail switching with a hard switch like class H & that these were visible on an oscilloscope. What kind of voltage are we talking about here just out of interest?
I guess it must be small & high frequency, enough to upset some people obviously
Thanks for sharing your circuits & your insight.
Bests, Mark.
Bests, Mark.
What kind of voltage are we talking about here just out of interest?.
The voltage spikes arising on output waveform when the transition from lower to upper tier happens.
Hi Kanwar, yes i understand that totally What i'm trying to gather is what kind of peak voltage these spikes might be, no doubt the speed of the switching to the higher rail will have an effect.
I'm assuming that the faster the switching the higher the peak voltage of the spikes. As i haven't actually messed around with this arrangement yet & knowing you have, i thought you might be able to possibly give a ballpark figure of what you yourself experienced in reality
Are we looking at a few tens of millivolts, or hundreds of millivolts, or greater?
Bests, Mark.
Bests, Mark.
Bests, Mark.
The max voltage amplitude of spikes i have seen is less than 2 volts
That's just worst case.
You can make it pretty good. Invisible on a scope isn't too hard and better than that is possible.
One can make it completely vanished by use of controlled slew rate and use of optimum snubbers.
Agreed, that would be an ideal solution.Try class G (non-switching) with a Schottky commutator. It takes more output transistors, but nothing's free.
There is or should i say could be problems with this method though Have you considered that the instant the upper rail class G transistors turn on that they are going to be passing the full current draw of whatever the speakers demand? I looked into it & depending on the rail voltages you are looking at a hell of a lot of powerful transistors. Admittedly there dissipation will reduce as the voltage increases (above a certain point) but for my money it's just not economical.
If i was rich i'd go that route, as it is i'm not, so i'll use a cascoded output stage as i already have transistors to make this with the power output i desire. I figure that the cascode will eliminate any switching glitches on the output, or at worst case seriously reduce them. I can put up with some non linearity as the H amp will be driving a class A output stage
Might be the worlds first class AH amp lol.
You end up using the same size upper bank as you do in the lower bank. If you have 4 in parallel, you need 4 more on the upper tier for class G. C5200's aren't THAT expensive, and there's no reason to use anything with higher SOA because the max VCE on the upper bank is the difference between tiers. Even with reactive loads.
Of course, in The Real World, the bean counters won't even splurge for two miserable 50 cent predrivers (which would significantly improve performance of the RMX line), so I'm sure extra output pairs are out of the question there. But for a DIY effort, what's $10? Or $20 if you put 8 in parallel?
A 1KW Crest typically uses four 150W pair on the lower rails and three pair on the upper rails.
yeah, along with asymmetrical Tier voltages to further enhance the reactive load handling capability of output stage.
Still i will vote for Class-G if 2 tiers and decent efficiency is required along with good sound like mx2000 old qsc, if the job is high power PA go for 3 steps class-H straightforward like qsc ex4000.
- The Class - H Amplifier
