Magura said:
Save your praise....the grub screw is metric
Magura
-and how about the grubby creator?
Geez, I shattered a couple of end mills messin with copper last week. It's almost like the material envelops the cutter and grabs it. You must have a method to your madness. Nice finish!
World's Best $100 Pr. speakers
Here's some info about the drivers that I used for my BIB that I'll be bringing. I used OSB board, the Pioneer BOFU drivers and the tweeter that Mr. Chang discovered...
http://www.diyaudio.com/forums/showthread.php?postid=1325468#post1325468
The biggest novelty is to get full range response at that price, but they sound good by any standard.. and the OSB looks mighty cool.
Nice review by Lynn Olson about the RAAL tweeters that will be discussed and demoe'd at Burning Amp By Aleksandar Radisavljevic, founder and owner of RAAL
http://www.diyaudio.com/forums/showthread.php?postid=1326088#post1326088
You are about to have that problem solved
Magura
Variac said:6mm shaft instead of 1/4" I suppose...
I guess I will save my praise!!
I have these old Shallco's with 1/4" shaft..so I guess I don't have to rig the awards to get some knobs,...
I chose 6mm as it's easily modified to 1/4.
...and yes we will probably need to have Vladimir overlooking the voting process
Magura
Smashing both Pumpkin and Sy's Pumpkin Smasher
why I have impression that this Gadget can both mentioned preamps ............
I have slight impression of that, just because I have this:
Re: Smashing both Pumpkin and Sy's Pumpkin Smasher
It is because of the spider (lookie behind the preamp)
Re: Re: Smashing both Pumpkin and Sy's Pumpkin Smasher
No, it is because the dust. Dust has special shock absorbent properties that minimizes microphonics!
Out of 4 things I have slotted to bring to Burning Amp, the JFET/MOSFET open loop preamp and "Almost Blameless " amp are very happily situated in my living room and playing away as I write this. I'm eager to audition them on another set of speakers. The "Half Nelson" Zen-like amp has been tested, and is in final assembly. Hopefully my tube/JFET hybrid amp will be working by Sunday, but even if it's not entirely there, I'll bring it along, as it's a bit of an unusual package. If nothing else, this event has forced me to bring several of umpteen projects to some sort of completion....
I do not know if you guys are checking original BA thread. I posted new schedule over there, please check it out and give us your comments.
Here is the link:
http://www.diyaudio.com/forums/showthread.php?postid=1326870#post1326870
Here is the link:
I had a look at the schedule - gives me a a little time to get my butt into gear in the morning and get lost finding the place... Seriously, I'll be around as early as I can. I'll be bringing the stuff I mentioned, a servicable TT, interconnects, etc. What I'll mainly need is access to some efficient speakers for the "Zen" amp and my tube amp. The Mostly Blameless beast shouldn't be so picky, as it has a little more capability. I'd like to meet some of the local folks and rub elbows with some of the bigwigs, too. There's no reason why some of us shoudn't be able to get together informally at intervals for demos and such.
Here are some photos of the Twisted Pair Opus DAC
Come hear it at the show!!
http://www.diyaudio.com/forums/showthread.php?postid=1327692#post1327692
So, here are the awards all ready to go....come and get yourself one
http://www.briangt.com/gallery/album64/PICT0153
Magura
Magura
- General Interest
- Everything Else
- The Burning Amp Festival-Burning Gadgets Preview
