I am bringing a small CD/DVD player. It has optical digital, coaxial digital and analog out.
I am also bringing a high performance processor (AKM DAC and National Semi LME chips on the output). It only has coaxial digital in.
AR2, I will send you a PM with contact info if you have questions.
janneman said:Announcement in Oct issue AudioXpress.
Jan Didden
Wow! This is the only international organization I'm involved with... and proud to be.
I have nothing expressive to show, all my gear is very humble, but I can bring couple of condenser mics, a 16 channel mixing console, one 2x80W tube amp, and pair of phased array speakers for those who want to sing and play guitar.
Thank you SY for letting me know about the festival, I did not look in "Everything Else" a long time!
SY said:Bring what you like, but most people don't bring anything other than a good attitude.
Some guitars and songs will be fine to add to a good attitude, right?
Jeb-D. said:
Humble That's a lot of juice!
SY saw it; it's still humble: below 10W it is fine, the 2'nd harmonic is below 70 dB, no others are visible, but above 10W all spectrum horribly start growing up, like a grass when it start raining. I need to tweak the 1'st stage before showing it to somebody except listeners on concerts... Also, a PS filtering for 800V needs more juice: intermodulation with 120Hz start showing on a power (though again a 2'nd order only, but it is horrible though), so more electrolytic beefing is necessary.
janneman said:I'm bringing a regulated tube power supply that can deliver up to 500VDC at up to 0.5amps. Maybe we can try to mate that to your amp to see how it works.
Edit: re-reading your post it looks like you need 800VDC.... My elcaps won't keep up with that....
Actually, 400 and 800. Thanks anyway!
Edit: I saw a pair of 0-500V regulated power supplies in Syclaboratory, they were nice!
Hey, it's called Burning Amp , so we are kinda obligated to ..
Fine answer
Since we are really close to the event, let me please stress this out:
Please make sure that you have a clear directions, and map for the event if you are not familiar with the area. It is very easy to get lost in many roads that are there. That area is really nicely tucked right under the GG bridge. Interestingly not many people know about the place.
A few tips - If you are going FROM San Francisco take Alexander Ave. exit If you pass it you have to look for exit from 101 and turn around. If you are driving toward SF than again take last possible exit right before Golden Gate, make a right turn, drive under the bridge and follow the road base on directions.
Here are the directions on Google map if you are coming from SF. Hopefully the file will fit...
The best advice I can offer to get there is to remember it is right on the water, right on the east side of the bridge tower, right next to the Discovery Museum. Knowing that much you can "navigate" there.. and will arrive a lot more quickly than you expected.. You can actually see Horseshoe Cove below from the bridge.
Newsflash:
Jason, the mysterious founder of DIY Audio will be there!
Newsflash:
I have some works in progress: one is a woofer used to play back whale calls for an art installation (corner frequency 17 Hz), and another is a tall three-way cabinet more or less complete, but still needing a crossover and drivers. I tried some different construction techniques which seemed to work OK and might be useful for others. Would people be interested in seeing them?
- Member Areas
- Clubs & Events
- The Burning Amp Festival- an Audio Happening
