The BA-3 as preamp build guide
Small delay...but don't have progress here
Maybe some can look over it.
This is my second PCB. M first try es with recommended Toshibas now I change to Fairchild (2k trimmers for P1,P2)
and check the JFets. For my I don't get it now.....but I have a lot of Hifi gear here, so I'm not blocked for my sound sessions..
Joined 2019
@DIYHarry -
This is more a question for others and a learning chance for me... So, apologies if this is completely irrelevant. Maybe, I'll get lucky...
Is this a case where the flywires have maybe put too much 'distance' between the MOSFETs and the source and/or gate stopper resistors?
I've seen that mentioned in a few situations. Typically that's for MOSFETs for power amp output stages though. I fully, 100% admit that I don't know if that's the situation here. I also have no idea if that's how that problem manifests itself as a symptom or if it even applies.
Reactions: 1 user
Joined 2004
Thanks!
Mil-Spec Coax, 50 Ohm, RG-178, 30 AWG (7x38) Silvered Copper Covered Steel Conductor,
PTFE Insulation, 95% Silvered Copper Braid Shield, FEP Jacket,
Commercial, non-QPL
I wonder if I should be concerned about the steel conductor? Maybe it
doesn,t matter as perhaps an audio signal passes on the outer skin
which is silver copper?
https://catalog.belden.com/techdata/EN/83265_techdata.pdf
care to explain methodology of your testing with scope?
it was not the measurement.....it was the desk power supply cabling.... I fix this on Wednesday and finally I got a confirmation from stuartmp with his video https://www.diyaudio.com/community/...he-wolverine-build-thread.385920/post-7515968
so to all...DO NOT wire GND-PE with your floating supply...for some reasons I overlook this topic....past erros apear due a ground loop from supply-wave generator- and scope----I knew it...put dont look there...:rolleyes:
please see correct calbing below..
