I am having a bit of trouble locating filter caps at a reasonable price.
A new 10,000 uF 63V cap costs R110
I can get two second hand phillips 10, 000uF 63V caps for R100
I don't know how to test them thoroughly though.
Will 63V caps work with in psu which supplies +58Vdc and -58Vdc?
I would not apply 58 volts to old capacitors that are rated for 63 volts. I'd try to find a couple of caps rated at 75 or 100 volts.
If you decide to try these 63 volt caps, reform them thru high-value resistors (47k) before you attempt to apply full voltage without the current limiting resistors.
Wagener said:I am having a bit of trouble locating filter caps at a reasonable price.
There is no firm rule on this. Anything over 10 years is suspect, 20 years highly suspect (assuming you can read the date code on the cap). Of course if they are leaking or dented, be very wary.
I've seen 30 year old electrolytic caps that worked just fine, and fairly new ones that failed. I tend to look at the manufacturer and the quality of the cap. Computer grade and high temp (105C) caps tend to last forever, while consumer caps from cheap makers fail withing a few years.
Phillips is a good brand. If the caps seem to have low leakage on a DVM ("resistance" slowly rising to infinite), reform them by supplying a trickle of current to them overnight, as the previous poster suggested. They will probably be fine if they are not extremely old.
If a used cap cost already half of what one retails new, I wouldn`t bother to buy used ones - especially when You don`t know how old they are!Originally posted by Wagener
I usually don`t buy even "new" surplus caps for much more than 10% of the normal retail price.
I don`t buy anything much older than 5 years.
I assume this is for an unregulated power supply.Originally posted by Wagener
If so, IMO caps rated for 63V are very marginal for unregulated +/-58VDC power supply.
Taken into account that there may be line supply voltage fluctuations, I`d consider about a minimun of +20% of the intended DC-supply voltage as safety margin for those caps.
