I hate to beat a dead horse ... but this will make you laugh.
MCM finally sent me a note saying that it is normally not in their procedure but they would replace the transistors (ON Semi 2N5416). I felt grateful (let me lick you're azz, MCM). No explanation about the sex change though.
The transistors arrived and I finally got around to testing them ... SAME RESULT. NPN. B-C LOW RES, B-E LOW RES, C-B OPEN.
Maybe I'm loosing my mind, maybe I never had one.
If anyone wants to check these out send me your address.
Your right EW, I probably won't get anywhere with them on email.
I had great luck with ON Semi, they sent me 10 MJ's for the Leach amp for only postage cost. I simply explained what I was using them for.
Allied has a good stock of transistors (at least what I have been interested in) and prices are good.
Digikey is hit and miss and there prices are too high.
http://www.mouser.com
Central Semiconductor, STMicroelectronics
Central makes obsolete JEDEC parts, ST still makes these for industrial use.
2N3439/40 and 2N 5415/16
About $0.65~$0.85 each.
No minimum, and in stock.
I CALLED MCM AND DISCUSSED THIS LITTLE THING WITH ONE OF THEIR TECHS. HE COULD NOT IMAGINE THAT A PROBLEM EXISTED SO I ASKED ON AND THIS WAS THEIR RESPONSE -
Thank you for contacting ON Semiconductor
The 2N5416 device is cancelled since Septemver 1999 and we do not
manufacture it any longer.
Regards,
JJ
ON Semiconductor
Technical Information Center
Subject: Transistor Problem
Description of customer request:
I have been in discussion with MCM, an online supplier of electronic
equipment, about a transistor type, 2N5416 (PNP), they supplied to me in
September 2006. The label on the collector is ON.
The particular units I received tested NPN. I notified MCM of this
problem and they sent replacements which also tested NPN.
I was since told that ON no longer manufactures 2N5416.
Is this true?
PASSED THIS ON TO MCM AND THIS WAS THEIR RESPONSE -
Date: Wed, 13 Dec 2006 08:56:37 -0500
To: brett_h_l@qwest.net
Subject: RE: Attn: Gary [Fwd: Service Request #78946 - Transistor Problem]
I checked 6 2N5416 from stock and confirmed they test as NPN. Pulling stock.
We apologize for any inconvenience.
Gary
MCM tech. dept
ph 937-434-0030
ph 800-543-4330
fx 800-765-6960
e techc@mcminone.com <mailto:techc@mcminone.com>
650 Congress Park Dr.
THE WORLD IS A SAFER PLACE.
Regards,
JJ
ON Semiconductor
Is this true?
Gary
MCM tech. dept
ph 937-434-0030
ph 800-543-4330
fx 800-765-6960
- Testing Leach Low TIM
